another 13 speed problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cumminsISB, Mar 10, 2014.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    For a few weeks now in a coast or float, with tranny still in gear it makes a growling/grinding noise. Not sure what is causing that. Now last couple of times I have been backing up an incline it tries to come out of gear and grinds. Any ideas what would cause these problems. My dad said the growling sounds like a bearing.
  3. spiderx4
    spiderx4 Bobtail Member
    19
    Jun 8, 2012
    Santa Rosa, CA
    bearings most likely, very common to fail
  4. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    How hard is it to rebuild one and what's a kit cost?
  5. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    Does the noise change at all while driving like on rough roads with suspension movements. Make sure your suspension height hasn't changed any. That can put you're driveline in a bind and growl at you. Neutral or in gear it sounds horrible.
    puncher and cumminsISB Thank this.
  6. wore out
    wore out Numbered Classic
    16,842
    206,329
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Check the spring on top the trans at the back, coming out of reverse only on an incline says mount trouble to me the whine or growl in a coast says the same if the rear is dropping. be certain to check the bell housing bolts they are bad to come loose and cause several different anomilies
    puncher Thanks this.
  7. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    No sir. Only does it in a coast, no change in sound on different surfaces.
  8. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Is this spring external, like a mount. Just changed the engine mounts 2 weeks ago. Will crawl under and check those out sometime in the next couple of days.
  9. johnnyreb0706
    johnnyreb0706 Light Load Member
    74
    17
    Oct 28, 2012
    virginia
    Could be the x-y splitter. If it is it's not s cheap fix but when it fails you're sitting.
  10. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Yes he's talking about your rear transmission mount across the frame rails with springs on it. Check your slip yokes and make sure it's not almost compressed all the way. Wore out is thinking like I am on the driveline getting in a bind
  11. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    I thought they did away with those. Are they on top of the tranny? Thanks for all.the replies.
