When idling I leave my fan on. Once the clutch on my compressor kicks off, my bunk blows hot air. Is this a bad expansion valve? I just replace it, my orfice tube, drier, and front condenser. Had a good vacuum pulled on it
Another a/c question
Discussion in 'Peterbilt Forum' started by roadwork, Jun 15, 2014.
Sounds like you may have a freon leak.
Turn off your engine coolant loop valves that feed the bunk. Under the hood on the passenger side. Small hoses.
Also be sure to run the A/C fan in the dash as well. -
I have the valves closed for my rear heater in my bunk. I don't have a leak, if I had a leak I wouldn't be able to cut the ac off for 3 or 4 minutes then turn it on and it blow cold again!
This may be a dumb question but are the coils or anything freezing up.
As soon as the line frost's up the clutch kicks off on the compressor
