Another CAT-tastrophe...6nz cutting out after start up
Discussion in 'Trucks [ Eighteen Wheelers ]' started by KittyKicker, Jul 25, 2018.
  1. KittyKicker
    KittyKicker Light Load Member
    196
    100
    Dec 27, 2015
    Hello again, everyone. Ok, so I posted before about my 6nz cutting out after start up. Basically, it fires up just fine, runs for a few seconds, cuts out, then right before it dies completely it catches itself and runs great. No codes. I've checked the fuel pressure, wiring, everything. I've replaced the ignition, cam, crank, water, manifold, oil, fuel, intake temp sensors as well as the injector harness and the harness from the sensors to the ECM. Also put on a new fuel pump. Ran a new power wire to the ecm with an in line fuse. The other day I put one of my drivers in it and sent him on his way. He got 5 miles down the road, the truck died. He restarted it and it died again. We couldn't keep it running for more than 10 seconds. No codes, all gauges read normal. Got a new ECM, had it programmed and put it on. Truck fired right up. Drove it around, let it run for 90 minutes or so. Perfect. Parked it, lubed it and put steer brakes on it. Fired it up again, ran for a few seconds and stumbled again just like it did before. It didn't completely shut off, but obviously there is still a gremlin in this #### thing....
  3. pavrom
    pavrom Road Train Member
    3,185
    7,305
    Apr 29, 2012
    NE illinois
    Pop up the dash and check if all the wires tight ... especially on the starter ....I had similar issue
    Oxbow and KittyKicker Thank this.
  4. KittyKicker
    196
    100
    Dec 27, 2015
    I've had the dash completely torn down. Checked starter wires, grounds, etc. Not saying I couldn't have missed something.
    Oxbow Thanks this.
  5. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Collapsing fuel line possibly.
  6. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    A loose harness under the hood? If it dies while driving, my guess would be the bouncing makes something move and kill the ignition.
  7. KittyKicker
    196
    100
    Dec 27, 2015
    Every line except the return on the back of the head is new. Fuel pressure is good too.
  8. KittyKicker
    196
    100
    Dec 27, 2015
    Well I started it and grabbed and pulled and shook and wiggled every wire I can see under that hood and I haven't found a thing. Never made it stutter or anything.
    Oxbow and Zeviander Thank this.
  9. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    The ecm also gets switched power from the fuse panel also. If that circuit gets interrupted its the same as turning tge ket off. No codes no nothing. A sharp mechanic/dealer will have a schematic to find the wires on the ecm plug and the truck plug. Good luck
    KittyKicker Thanks this.
  10. Troy_
    Troy_ Road Train Member
    1,006
    6,633
    Dec 13, 2017
    Roma, Alberta.
    it is your camshaft sensor, mine was doing the same thing. it will cut out until the crankshaft sensor takes over and that's why it fires back up just before stalling. I just noticed you have replaced that sensor already? maybe check the wiring from the sensor to ECU
  11. QUALITYTRUCK
    1,810
    1,772
    Jun 14, 2009
    romulus,mi
    Bad ECM. Very common on a CAT Adem 120 pin ECM. It will progressively start happening more often if given more time.
