another dumb shifting question: differences between trucks.
Discussion in 'Experienced Truckers' Advice' started by mugurpe, Sep 10, 2016.
  1. mugurpe
    mugurpe Medium Load Member
    395
    274
    May 5, 2013
    Arlington, MA
    I've been driving semis for about 3 years now, but not full time (I run the company). We use almost exclusively rental trucks so far, so I've probably driven 20 different trucks, mostly penske rentals. Of the manual trucks I've noticed a drastic difference in how they shift. They've all been 10speed eatons, but various engines. Some float really well but I have a tough time double clutching them and getting the revs right, but they float right in, other trucks on most gears I can't get them to even float out most gears let alone back in, but I find them easy to double-clutch. I've driven IH's with cummuns, IH's with maxxforces, volvos with cummins, volvos with volvo engines, freightliners with DD and with cummins, a mack with a mack in it. . The last 2 trucks we had, a SA IH with a maxxforce, and a volvo TA with a D12 where exact opposites, the volvo was a bear to double-clutch, especially bobtailing, and I couldn't float the IH at all.
    My question is what's up with the variety of feels? Is it really the differences in the engines? mileage? clutch type and setup? I'll be shopping for a permanent truck soon and could use some more background on the difference. Personally I much preferred floating that volvo and giving my left leg a rest. What's the scoop?
    Thanks.
    Lepton1 Thanks this.
  3. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Two brand new trucks with the same motor, same transmission and same spec will drive/shift differently.
    Between all the trucks I've driven for my company, each and every one of them have been different. From clutch feel to shifting feel and everything else. It's just what it is and you have to just get used to how THAT truck drives and do your best to drive it well.
    What doesn't help is people who don't know how to shift playing the "grind it till they find it" game with the transmission. That wears out the gears and makes it much more difficult to float precisely for someone who knows how to do it.
    Lepton1 and mugurpe Thank this.
  4. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    I'll second that...hell, some days i cant shift to save my life in the same truck. ( im o.o)
    I have found the combo of cummins and eaton to be the simplified version of 10 speeds.
  5. okiedokie
    okiedokie Road Train Member
    13,476
    105,452
    Jun 13, 2011
    PNWET
    Somedays your hot and somedays your not. It usually takes me a few hundred miles to um adjust to a different truck.
    mugurpe Thanks this.
  6. mugurpe
    395
    274
    May 5, 2013
    Arlington, MA
    Why is the answer always a Jerry Reed song?
  7. Grumppy
    3,181
    11,116
    Dec 11, 2010
    West Monroe, La
    As for Mack, they shift sssllllooowww.... you gotta take your time with that Mack. When you come out of one hole, its a full second before it will float in that next hole. I ran Mack's for 11 years for Waste Management. When I left there, I road tested in a Farmall (International) with a 10 speed Eaton Fuller & the guys says; are you sure you have driven a big truck before? You're not trying to pull my leg are you? I said no, I been in a Mack for 11 years. He said; Oh, carry on then. You gotta be quicker in & out in this thing.
    I've been in Freightliner's with 10 speed Eaton Fuller's for the last 9 years. I agree, although they are the same, there is differences in all of them, especially when new.
  8. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    In my opinion, Cummins motors lose RPM's faster than others, causing a quicker shift.
    Also, some engine fans run more than others, causing a quicker shift when it's on.
  9. Dave_in_AZ
    416,686
  10. tscottme
    tscottme Road Train Member
    Some engine/tranny combos drop RPMs fast and some slower. Floating & double-clutching is about rhythm. At my first job they had Deeeetriot engines and Eaton Road Rangers, IIRC. The RPM drop when changing gears was VERY different than the Hodge-podge of engine/tranny used during CDL school. GGGRRRRRRRRRIIIINNNNNDDDDD and we're in.
  11. AModelCat
    161,973
    Never had issues floating with a Cat or Detroit but I cannot float or clutch anything International. Just grind until it jams in lol.
