Another honest to goodness question....
Discussion in 'Questions From New Drivers' started by Tonythetruckerdude, Sep 19, 2013.
  1. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,906
    49,695
    Dec 8, 2012
    hunting...../ retired
    mje just proposed a good question , and it makes me wonder about this one. If you are injured while on the job...get your treatment , get cleared to go back to work ....what sort of issues/problems would you run into looking for a job. I mean if a Dr. clears you medically/physically able to work ...where is the problem?
    mje Thanks this.
  3. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    There shouldn't be a problem unless an employee shows a propensity for getting hurt at work, i.e. multiple workman's comp claims within a limited period of time.
    mje and Tonythetruckerdude Thank this.
  4. Tonythetruckerdude
    2,906
    49,695
    Dec 8, 2012
    That's the way I was leaning too. I mean if an applicant comes in and has had several work related injuries and has filed WC claims several times ...I'm seeing a pattern develop. But if a person got injured and had to go through a period of treatment and had successfully completed that treatment , and was cleared by a Dr. to return to work with-out any restrictions...I see zero issues.
    mje Thanks this.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    They also want to document preexisting conditions (especially back problems) so they can limit their exposure in the event of reinjury
    Tonythetruckerdude and mje Thank this.
  6. Pilgrim007
    Pilgrim007 Light Load Member
    125
    80
    Sep 9, 2013
    I also suspect it is for workers compensation.
    1. The employer pays the workers compensation premiums not the employee.
    2. Workers Compensation is provided by a Insurance company at State level. Base rates are worked out comparing other companies of the same business and the number of claims within that business. IE; Construction Workers are high on the list whereas a Teacher is lower down. This means Education facility pays less Workers Comp than a Construction Company. However if the Education facility has a lot of claims their contribution % rate increases. Likewise if a haulier has a lot of Workers Compensation claims against it they pay a higher rate.
    3. Also although companies fall in to levels of rates due to the dangers involved, a company can pay a lower rate by having a good safety record and no claims against it.
    So if an employee has a history of say back problems, statistically he or she is a higher risk of claiming workers comp and costing the company more. Which could also be a reason not to be hired!!
    The same principal works with unemployment insurance but on a Federal Level, the more people you send to the unemployment lines the more a company pays in premiums. That is why most employers prefer you to resign rather than fire you!
    mje Thanks this.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    You should be able to return to the job you were at because you are covered under the FMLA laws for 12 weeks.
    If you were terminated as the result of a wreck then that would be the underlying issue.
    Let's say you exhausted your FMLA, your employer can let you go as an at will employee. You will draw your workers comp until healed and released by the doctor. Then if you are unemployed and willing and able to work you can draw unemployment off them.
    Your next employer will look for a trend of filing wc claims. If it's just one or two spread out it shouldn't be an issue. Is this guy accident prone? Is he gonna tear up our equipment?
  8. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    Some places will avoid you,
    even AFTER JUST 1 w/c CLAIM......
  9. dracon
    dracon Light Load Member
    79
    116
    Jan 8, 2008
    new york
    Ok let me please expand on this question and get some thoughts. As some of y'all may remember, I suffered a mild stroke about a year and a half ago. I have been on SSDI ever since, I've completed my physical therapy, got the doctor to say that he'll write a letter saying I'm alright to return to work, and am positive I'll pass a DOT physical. currently unemployed looking to go back OTR, what issues might I face?
  10. SlowPoke44magnum
    407
    519
    May 3, 2009
    Walbridge,Ohio
    The biggest issue you may face is finding a GOOD company that will take a chance on your history. I'm definitely not knocking you at all, so please do not take it that way. At the LTL outfit I used to work for we had a driver that had a stroke while on duty, they found him in the drop lot of one of the terminals and after the company's doctor signed off to let him come back to work they started nit picking at him for every little thing until they built a big enough case against him to fire him. We all knew it happened just to free the company from potential further medical costs due to his pre-existing condition. Many other drivers got away with far worse stuff than they were busting his chops about. But therein goes to show the politics of some LTL outfits.
    Tonythetruckerdude Thanks this.
  11. Tonythetruckerdude
    2,906
    49,695
    Dec 8, 2012
    Or lots of companies in general......
