another inverter issue!! HELP!!
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by the flying scotsman, Jul 11, 2011.
  1. the flying scotsman
    the flying scotsman Medium Load Member
    542
    222
    Jul 28, 2010
    Portland, OR
    i bought a 1575(3000 surge) cobra inverter and fitted it to my truck but while it will run the chargers and little cooler and stuff it wont run my 900w microwave, the inverter shuts off and i need to restart it...
    i started to think i should have got a larger one but heres the thing...the cables i am using are the largest size that my inverter will hold and it is really as close to the batteries as practical...
    but what really is confusing me is that my buddy has the EXACT same inverter bought on the same day..and i tried my microwave in his truck and it works fine, which leads me to think it may be something to do with my truck or setup and not the actual inverter...
    does anybody know of any issues like this or would it be anything to do with lack of amperage from the batteries as my truck isnt the best at holding a charge when running appliances with the engine off..(but it is doing this with the engine running)
  3. Trilleth
    Trilleth Medium Load Member
    432
    243
    Jan 17, 2011
    Southern California
    What else do you have running at the same time? We have to shut our microwave down sometimes in the middle and restart if we are running other items.
    Also, you have an older truck, so that could be part of the issue. Your buddy's truck may not be running as many items (wattage) at the same time. Have your batteries checked; new batteries will sometimes help this issue.
    Or call Joe and make him troubleshoot it... but he's going to bed soon. :biggrin_25518:
  4. DMB_FAN
    DMB_FAN Bobtail Member
    montgomery, al
    I would assume that if the truck will start, the batteries aren't an issue. check your wiring setup (compare to your buddies wiring if possible) and especially your ground from the inverter. Cobra is a good name, they don't make lemons. It will more than likely be a wiring issue when it come to pulling a heavier load.
    Hope this helps, if you have anymore questions feel free to ask. I'll try and help the best i can.
  5. the flying scotsman
    542
    222
    Jul 28, 2010
    Portland, OR
    new batteries recently....ill double check the wiring see if i cant shorten the cables some....also do you guys have sirius xm...im trying to figure out where best to put the antenna thingy..
    i dont know whats worse...not having bbc world...or having it intermittently ...
  6. AXE
    AXE Road Train Member
    1,651
    688
    Jul 2, 2010
    Chandler, AZ
    I have XM.....I'm not using the "puck" that comes with the unit, bought the antenna that looks like a potato masher and mounted it to my mirror bracket on an 05 Columbia. If that isn't an option for you I've seen then mounted on the visor and have also seen it mounted on the side air deflector up high.
  7. Trilleth
    432
    243
    Jan 17, 2011
    Southern California
    We have Sirius and do it the same way as Axe. The good thing about that method is that we can turn the antenna down out of the way when I (never Joe) have to drive under low trees. :biggrin_25526:
  8. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    we have xm and i have the little puck on the INSIDE of the skylite (volvo 780) works fine
  9. optlock
    optlock Bobtail Member
    14
    Mar 29, 2011
    Greensboro NC
    Remove the inverter and put it on your buddys rig then run the microwave.
  10. Java Joe
    Java Joe Light Load Member
    286
    61
    Sep 19, 2008
    Sacramento, CA
    She's thinking of the CB antenna :p but we do have the small vertical antenna mounted to the side mirror bar and it works great. The 'puck' I used to use worked well until you were in OR & WA facing the wrong direction, then the signal got partially blocked.
  11. Java Joe
    286
    61
    Sep 19, 2008
    Sacramento, CA
    Also, as for the inverter, depending on the other 'little' things you have running, it could be pulling more than the 1500 watts that it is designed for. If it's not too late I might suggest returning it and getting a 2000W or 2500W inverter. Our 2000W inverter works well with the microwave, Refer, TV, PS3, 2 computers, and 2 phone chargers... all running at the same time.
    the flying scotsman Thanks this.
