on a side note i need to clean the windows in the peek a boo hole on the passenger side door is there a way to take the interior glass out to clean the glass on both sides?
another question about the 1997 kw
Discussion in 'Kenworth Forum' started by bbigcnote, Jan 20, 2013.
daylite doors are a pain to clean, the last time i removed one of the windows on mine it cracked, yo can remove it with a precision screwdriver ensure its a flat one. and just run it no the outside window in between the rubber locking tab. dont cut the ruber as you will need it later to re install the window. when you remove the rubber, the window should have some play. use the same screwdriver and out it in between the rubber seal on the window and the window itself and move it left to right and up and down ti cut the glue off do the same till the window slips around in the rubber. now take another flat screwdriver and put it in between the door and the rubber seal on the window and do the same you sould be able to remove the glass by then. when you put the window back, put the rubber seal first on the door the get some silicone and apply a small layer inside the rubber seal where the window sits. put the window back in carefully from bottom to top and use the precision screwdriver to ensure the window sits in between the rubber seal. take the rubber locking tab an put it on the space it came out of. fit it in between the space and use a flat screw driver and a hammer and gently tap the rubber in as you go around the window.
Or open the door panel and clean it on both sides.
I personally replaced this window....its very tricky until you have done it and understand how it fits.
There is a thread on this site (I started) that discusses replacing this peeper window.
