Another Question for a Flatbedder...
Discussion in 'Questions To Truckers From The General Public' started by Ducks, Apr 17, 2007.
  1. Ducks
    Ducks "Token Four-Wheeler"
    3,415
    3,582
    Jan 1, 2007
    Southeastern Pennsylvania
    I was heading back to work this afternoon and a flatbed hauling steel pulled out (safely) in front of me. Without a doubt, this was one of the longest flatbeds I've ever seen. What struck me, though, was that the space between the axles in the rear tandem was probably five feet or so.
    I may be way out in left field, but I assumed that when a trucker slid the tandems that s/he changed the position of the pair of axles, not the axles individually.
    Can the axles be moved independent of one another, or was this just a different set-up on this particular trailer?
    Thanks!
    Ducks... the insatiably curious... :yes2557:
  3. dstockwell
    dstockwell Light Load Member
    278
    6
    Oct 11, 2006
    Georgia
    Lots of flat bedders run split axle trailers. I do not know if they are adjustable.
  4. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Called a spread axle.
  5. dstockwell
    278
    6
    Oct 11, 2006
    Georgia
    Yep, my bad on the name of it..
  6. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    No problem.:biggrin_25523: If you ever see a flatbedder trying to back (most seldom have to) and they can't get it in the hole at the truckstop. They will blame it on the spread axle!:biggrin_25523:
  7. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    it is a ten fot spread usually but somtimes less (from axle center to axle center.) If the axles are together like a mormal tandem you can put 34k ounds on them. if you spread them 10 foot apart you can put 40k pounds on the same axles just because they are spread apart I think 6 fot spread gets you 38k pounds
    still cant go over 80k gross though
  8. Calinn
    Calinn Bobtail Member
    42
    9
    Apr 15, 2007
    Columbia, KY
    The spread axles are set at a certain spacing based on the way they are ordered from the factory (weight ratings, etc.)
    Having gone from a 53' dry box to a 48' flatbed, they are harder to back. It takes twice the steering input to get that trailer to pivot.
  9. Burky
    Burky Road Train Member
    Actually, there are flatbed trailers where the rear axle only can slide, which allows the trailer to be run as an open spread axle, or an a closed tandem axle trailer. In the open position, there is the standard 10'1" between the center of the axles and it is a spread axle trailer and meets the weight laws applicable for that. In the clossed position, the rear axle is slid forward to the standard closed tandem position, with a 3'"6" distance from center to center on the axles. These are a fairly new design, over the last few years and not all that common, but gaining in popularity pretty rapidly. You could space them at any point along the way if the locating holes are there, though there are no weight advantages to doing so.
  10. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    you sure there isn't any weight advantage other than 10 foot? We have some PET scanner trailers that arrived with 6 foot spreads and they say it's because they only have 38K on them so they didn't ned the ten foot. I always considered a six foot spread a "canadian spread" not even sure if that's right but I know they don't honor the ten foot spread. Our MRI scanners all have ten foot spreads
  11. Burky
    There may be a formula for other spacings, but 10 is a standard one. I'm not sure if they have the holes for alternate spacing or not. Some manufacturers try to make things as idiot proof as possible.
