ant red light
Discussion in 'CB Radio Forum' started by flipside74, Aug 5, 2013.
  1. flipside74
    flipside74 Bobtail Member
    I have a new cobra 29 classic, new coax, new antenna and mount on mounted on mirror of mack truck. Have ground wire from antenna to frame of truck. My antenna is tuned and my swr on channel 1, 20, 40 are all good and i get great reception.problem i have is when i have my dynamike turned up or hold mic a little to close to mouth and speak into mic my red ant light blinks on. When i key up and dont talk, turn dynamike down, or hold mic further away and speak i dont have this problem. What could be causing this.
  3. Ridgeline
    22,374
    116,078
    How re you checking the SWR?
  4. flipside74
    External meter between radio and antenna
  5. kc0iv
    kc0iv Light Load Member
    294
    233
    Mar 31, 2010
    Parkville, Mo
    It sounds like Over modulation.
    Leon (kc0iv)
  6. flipside74
    How do i fix over modulation
  7. 6string
    6string Bobtail Member
    49
    13
    Mar 24, 2013
    blinking ant light is not a big deal if it bothers you that bad you can have a shop adjust the swr meter pot
    it will not have no effect on your radio if it stays red when your talking then you have a problem
    but since its just blinking not a issue
    jessejamesdallas Thanks this.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yep. Could just be the light needs to be adjusted... But before doing so I would make dang sure your SWR is under 1.5 first... Don't rely on the radios meter to be accurate, check with a external SWR Meter, or better yet, if you don't have one, have someone with a Antenna Analyzer check the antenna. Any CB Shop worth a dang, will have a Analyzer.
    darthanubis Thanks this.
