Antenna for Cascadia
Discussion in 'CB Radio Forum' started by rainmakerr, Dec 3, 2013.
  1. rainmakerr
    rainmakerr Light Load Member
    100
    25
    Mar 15, 2012
    Centreville, AL
    I'm in a 2012 Cascadia and I can't get the SWR below 1:17 using a Wilson 2000, would a Wilson fiberglass antenna with tunable tip or a Firestik II help in this situation? I have tried the grounding strap with no change.
    Thanks
  3. Ridgeline
    22,461
    117,740
    How are you measuring the SWR?
  4. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    With a external meter that I bought.
  5. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
  6. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    I modified the factory mount by taking the outer portion off so that there is only the flat plate which bolts to the side of the sleeper, I increased the hole so that the new coax would fit through it since it had the small coax from the factory. I then bought a L-shaped bracket which I mounted to the flat metal plate which I mounted the Wilson 2000 to.
  7. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    Based on what I have read, the fiberglass antenna would work better but does not take the same amount of power as the Wilson. I run a Galaxy 29 which pushes 40 watts which shouldn't be a problem, but will it be affected by other drivers who are running amps on their radios? I am knew to this and still trying to learn what I can.
    Between the two; Firestik II and Wilson fiberglass (both are 4 ft and have a tunable tip but the Wilson has a ground cable as well) which one would you recommend?
  8. mike5511
    mike5511 Road Train Member
    3,146
    1,534
    May 15, 2011
    NW Arkansas
    I like the Skip Shooter. Looks like it has a nail in the tip.....because it does and it is tuneable. I buy mine from Ray in W. Memphis. (CB shop across st from McDonalds.) They are made in Mississippi so I'm guessing you can find one in the South. Oh yeah, come in lengths up to 6 or 7 ft. I forget which.... I use a 5 ft.
  9. falcon241073
    falcon241073 Heavy Load Member
    997
    360
    Oct 25, 2011
    Germantown, TN
    6' is tallest. I have a 4' but I'm going to try the 6' to see if its better.
