2015 Freightliner Cascadia
I have been using a TV in my truck for about 4 years. I have had good luck with a set of rabbit ears that sit on the window glass. I just roll the window down a bit & stick the antenna outside & it sits on the top edge of the glass, then just roll the window up on the mount.
https://www.amazon.com/gp/product/B001JSYCOC/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Now, when I say I have had good luck with these, I mean reception. But, I've already gone through 2 sets in 4 years because they dont hold up very well (cheap made).
I have searched the internet over including ebay & Amazon & I am not having any luck finding something that is better quality but more specifically, easy mount & un-mount each day/night without having to get out of the truck & walk around to set up or take down every day..... sometimes in the rain or cold etc.
I am pretty handy & have a small shop that I can build a bracket for the mirror or bird perch cb antenna bracket.
So, I'm looking for a GOOD antenna both in quality & reception that will be easy mount on or near the window, mirror or bird perch.
Any ideas? What are yall using for free TV? Any help would be appreciated.
Antenna For Free TV
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Grumppy, Aug 27, 2018.
Page 1 of 3
what tv you got. a good smart tv works good with little to know help
Grumppy Thanks this. -
BUMBACLADWAR, Jazz1 and Grumppy Thank this.
Had a Winegard that worked good enough for me.
Jazz1 Thanks this.
HDTV Antenna Fact or Fiction
Basically you should look for an antenna that can be easily situated in different locations and stowed easily. Finding the optimal location to match your truck’s orientation and the location of the bulk of the towers that might reach you is key.
If signal is distant and weak, you’re going to get signal distortion with passing trucks no matter your antenna. The type/brand of tv you have makes no difference as far as reception goes. Also I’m not convinced “powered signal boosters” provide any real improvementsnowman_w900 and Grumppy Thank this. -
I have good luck with the flat ones
Interesting posts. I tried a flat antennae on my smart tv at home and got 2 snowy channels
I’d dump my cable in a heartbeat if I could pull in local tv which broadcasts a few miles from my houseGrumppy Thanks this. -
You do know that the 2015 Cascadia has a built in TV antenna right? It seems to work well for me. I have 3 old antennas from the house I tried. Two unpowered and one that plugged into the wall for power. None worked as well as the antenna built right into the truck.
And don't be fooled about getting an antenna that is called an "HD" antenna or "digital antenna". There is no such thing. An antenna is designed to pick up something (or transmit) at a certain frequency. TV signals have always been the same frequencies. In 2009 the signal went from analog to digital, but at the same frequency which is why old "analog" antennas from 40 years ago still work just fine.Grumppy Thanks this. -
Yes, I used the built-in antenna for about a year & eventually (I dont know if it was the coax or the antenna but) it just wouldn't work any more. That's when I bought my first rabbit ears from the Loves in Jonesboro, Ar. Since then, I have not been able to find them anywhere in a Loves. I ordered the last one from Amazon. At Loves, it was $20.... from Amazon it was $30.... same RoadPro antenna.
I bought a flat one (powered) from Loves about a year ago & I couldn't get it to pick up but about 3 or 4 channels in the Dallas, TX area, when my rabbit ears would get 60 or 70 channels.
Page 1 of 3
