I got a 2015 International ProStar. I'm putting my antenna on the passenger side mirror arm where is the best place to ground the antenna mount?
Antenna Grounding
Discussion in 'CB Radio Forum' started by BigSnipes, Jan 19, 2017.
Page 1 of 3
To the frame , or the negative battery post if it's close by.
Ground strap from bracket to door hinge
ground strap across the door hinge 2 cab from door
Ground strap from cab to frame
Just for Giggles why not run a ground strap from frame 2 battery
I was always taught the RF and DC potential must be equalmike5511 Thanks this. -
You can't ground too much, the biggest white noise difference noticed on mine was when I strapped the exhaust pipe
bored silly, mike5511 and rabbiporkchop Thank this. -
rabbiporkchop Thanks this.
I try to keep all my ground straps 10 inches or shorterLast edited: Jan 20, 2017
bored silly and mike5511 Thank this. -
For ground strap to be effective it needs to be as short as possible sometimes getting it as short as possible is nearly impossible... especially in tight spaces as soon as I can get about 15 more feet of strap I'm going too it's needed on a freightliner
Page 1 of 3
