I know that a longer shaft increases the electrical length of the antenna, but I was wondering if I could use a really long shaft with a base loaded antenna and trim the whip down to a reasonable swr without adversely affecting the performance of the antenna.
This would be done on a truck, I just want to get the load a little higher and away from the truck, president radio and antenna with an amp, 9ft coax with 3 foot jumper. If it's not a feasible idea then I'm going to just get a fiberglass "top" loaded one.
Thanks in advance @rabbiporkchop and @Ridgeline
Antenna question
Discussion in 'CB Radio Forum' started by QuietStorm, Jun 22, 2019.
Page 1 of 6
QuietStorm Thanks this. -
Are there any problems that might arise from doing something like that?
Edit: found some at Walcott online.
Edit: guess I'll measure it up to see how long of a shaft I can actually use.Last edited: Jun 22, 2019
I would measure from the ground up to the bracket and subtract that distance from your height restriction and that will tell you how long the antenna needs to be. Then you can take your existing antenna and measure from the load up to the top of the whip and subtract that from the number you previously calculated and that will tell you how long the shaft needs to be.
I favor SKIPSHOOTER top loads for this reason. American made (WELL made) and about $25.
The experimentation above may take awhile. Have a substitute (and backup).
FWIW, I’ve had my antenna at nearly 14’ on spring without problems. That gets this sleeper mount Skip ABOVE the trailer).QuietStorm Thanks this. -
Edit: I pull flats so if it wasn't a studio sleeper it would be a lot better for radio.
Edit2: and aerodynamics, and looks, and storage space, but whatever, I didn't pay for it haha. -
The mount on the mirror arm has a 90 degree connector, I'll probably replace it and the stud if possible. I haven't taken the mount apart yet to see, but make sure you sand off the powder coat underneath and run a ground strap to where the mirror arm connects to the door.
Page 1 of 6
