i currently drive a freightliner century with stock antenna setup, i tried using a wilson 5000 with my cobra 29 but never could get the swr readings to an acceptable level. i have tried mounting the antenna on its separate mount and the on the factory mount that is part of the mirror, but the results are almost the same, also when i tried a new 18ft coax the results were even worse. would like to get a response from anyone with similar setup and if so did you experience the same and what can i do to fix the problem, which is bad swr and poor performance.
antenna/swr frustration
Discussion in 'CB Radio Forum' started by haze1, Oct 19, 2007.
Page 1 of 4
what is an acceptable swr level? and what is your swr on 1 and on 40? Is your antenna grounded?
i was led to believe an acceptable swr reading is 2 or at least 1.5 but keep in mind i am not that knowledgable when it comes to cb radios. the readings i had on channel 1 was 2.5 and channel 40 well over 3, and when i tried using new 18ft coax the red warning light on my radio came on when i keyed the mic. no i have not grounded the antenna, would that help and how do you ground the antenna.
is it a magnet mount or is it a permanent mount, and does the bottom of the antenna have a little wire coming off?
nope, not a magnet mount. its the mirror bracket type of mount and no the antenna does not have any wire coming off of it. are you suggesting that i might have to ground the antenna with some wire, if so where do i run the wire to on the truck? btw thanks for responding to my questions.
Well, im not sure exactly how your antenna works, so it might work that way it might not, but you would have to attach the wire to somewhere you know is grounded... chassie, some bolt, anything grounded.
i may be setting up dual antennas, and i need to pick up another antenna, and the cable, so i may be going to a shop tomorrow, ill check out that antenna and ask how to ground it if need be. -
Just in case the mount itself is installed incorrectly, it's worth a quick check with an ohmmeter. Remove the antenna but leave the mount and coax in place. Disconnect the coax connector from the rear of the radio. Put the meter on "ohms" and put one lead on the center pin of the plug and the other on the shell. The meter should not move, or show "Overflow" or Infinite or whatever it does when the two leads are not touching anything if it's a digital meter. If the meter moves to zero, you've got a short in either the coax or at the mount.
If, as we hope, the needle did not move, nor the display change when you touched the two parts of the plug, step two often calls for either being a contortionist or needing a second person. Touch one meter lead to the center pin on the plug (at the radio end) and the other lead to the center pin on the mount. NOW you should get a swing towards zero, or a very, very low resistance (like no more than 1 ohm). That tells you that the coax isn't broken, and is attached to the right part of the mount. Thirdly, have your helped touch his probe to the outer shell of the coax plug, and you touch the truck part that the mount is bracketed onto. Again, you should get close to zero ohms. If the needle doesn't move when you do this, your mount point isn't grounded.
Those three little tests should be able to tell you that the feedline and mount are OK, and your most likely need is, as mentioned above, either a better RF ground, or a "no-ground-plane" antenna, similar to those used on small boats.
Hope this helps,
-- Handlebar --
diddly dahdidah -
Only the silver load has the wire mentioned, not applicable in your case. No reason to make things overly complicated. Run a braid strap or 8 Ga wire, or even a length of mini 8 (about 18 inches) using the shield braid as your conductor from one of the 4 bracket bolts to one of the two Tor-X bolts that bolts the mirror to the door. Solder a 1/4" and 3/8" ring terminal at each end of your ground strap after measuring it for length. Most often this will be adequate ground. Connect no wires to the antenna. Nothing but the coax at the hardware bottom with the antenna on top, in other words normally. Also your stinger is too long, remove 1 inch from the bottom to start and go from there. If you are starting with a fresh 66 inch stock Wilson stinger it may be from 2 to 4 inches too long assuming your shaft is not longer than 18 inches. Since it is easier to remove than put back carefully measure between each cut taking no more than 1/4 inch at a time since you are using a radio and meter to make your measurements. I tend to be more caviler in cutting from years of experience combined with an analyzer which allows me to begin knowing where the resonant dip is and how much length corresponds to frequency. Better if you play it safer, you may only want to remove 1/2 inch to start since you do not really know where you are to begin with. Judging from your setup and stated readings I have no doubt you are still an inch and a half too long minimum combined with your grounding problem. Do as Mike mentioned let the coil see sky as much as possible while being as far as possible away from any part of the truck.
In short your stinger is too long and your ground is inadequate. I should add if you get a reasonable dip but still a little high like say 1.8:1 or so after tuning then you may wish to add a couple short flat braid straps inside the door hinge area from the door to the body across the hinge, to get the overall door to body ground better. Seldom is this needed unless the truck is a few years old. Remove a bolt on each side and shiny the metal before bolting the short (3 or 4 inch) length of strap across the hinge from door to body. I prefer doing this at top and bottom when I see it is needed. Usually by the time this step is needed one should also crawl around under the truck inspecting any ground straps from body to chassis across the bellows shock absorber(s). Typically when these corrode out you begin hearing noise (in your receiver) which alters when using the clutch or brake.Last edited: Jun 14, 2012
mike5511 Thanks this.
Page 1 of 4
