Antenna Warning, COBRA 50th Aniv
Discussion in 'CB Radio Forum' started by ADRENALINEJUNKIE, Jun 6, 2011.
  1. ADRENALINEJUNKIE
    ADRENALINEJUNKIE Bobtail Member
    39
    Jan 12, 2011
    Cobra 50th Aniv radio
    Had a 18' coaxal cable, adjustable antenna and it worked fine. Recently the antenna warning display came on. I beleived the cracked antenna to be the issue and after replacing it with a new antenna the warning display went away. Now after I return to my truck a few days later, once again I have the warning displaying.
    Tried contacting COBRA but they have not returned any of my calls. Any ideas?
  3. jugganaut
    jugganaut Bobtail Member
    47
    6
    May 6, 2011
    holy,denial
    what kinda truck
  4. stlwaco
    stlwaco Light Load Member
    276
    47
    Oct 4, 2009
    St. Louis, MO
    Has it been raining? I had an old antenna mount that would short out when wet. Caused the warning light to come on. Replaced the mount and all works well now.
  5. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    768
    193
    Jan 31, 2010
    Skid Row
    More than likely it is an antenna issue and not a problem with the radio.
  6. Yup
    Yup Medium Load Member
    569
    129
    Apr 2, 2011
    Everywhere,USA(Texas)
    poorly "tweaked" radio's often do this,I would start with checking the impedance on the coax.One end or the other could be bad and need replaced.
    Then check the mount and make sure the nylon washer isn't crushed at the stud.
    If you dont need 18' to run from the back porch to the front I would have the coax cut
    down to 12' or at the very least consider it when purchasing your next one
  7. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Agree it is likely the antenna is not working right.
  8. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    The self-diagnostic features on the new Cobra are pretty cool. I found them fairly accurate when put into perspective. Obviously, the digtal bars are giving you an accurate wattage or an accuaret SWR, but they give you a good general idea. I ran those self tests each morning with my pre-trip, just became part of the routine for me.
  9. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Nothing like limiting suprizes ...
  10. Dodgem250
    Dodgem250 Light Load Member
    58
    14
    May 2, 2009
    Maryland
    If your radio has been "Peaked & Tuned" as they say, the SWR/ANT warning light has to be removed from the circuit. Radios that have has power mods done, or clipped, or anything that changes the factory alignment for RF Power output will set off the ANT light, this is a major issue in the Cobra 29 radios (all of them).
    You can solve this issue by adjusting VR6 full off until the ANT light does not come on, there's no harm in the radio, once you've modified the radio, the need for the internal SWR meter is shot to hell and useless anyway at this point.
    Once you change the circuitry of the radio you have make other adjustment to compensate for the modifications, the ANT warning light is one of those things some techs out here fail to correct, and this is also the number one reason to own an external SWR meter, the internal meters can not be trusted.
    Good Luck,
    Dodgem250 at the CB workbench around Southern Maryland
    darthanubis and flightwatch Thank this.
  11. Yup
    569
    129
    Apr 2, 2011
    trusting the internal meter is foolish,it only "zero's" the radio
    It does nothing to "adjust" SWR
