Anti-gel trick is it true?
Discussion in 'Questions From New Drivers' started by OEF08, Oct 9, 2011.
  1. OEF08
    OEF08 Bobtail Member
    33
    5
    Sep 14, 2011
    St Louis
    99 to 1 ratio. 99 gallons of diesel and 1 gallon of gasoline would work as an anti-gel. Is this true???
  3. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    I don't know about that. I have used kerosene to thin the mix for my backhoe when I had the cemeteries. But on these new motors I have no clue.
  4. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    I have known several who have done this but in a greater ratio (1 gallon of gas per 20 gallons of diesel). With the cost of gas now days compared to commercial anti-gels this would seem somewhat silly to do. I am not aware of any immediate problems associated with them doing this but at the same time I am not certain whether long term problems (Injectors, injector pumps etc.) could be identified as being because of this act.
    On the other hand though from a strictly chemical perspective, it probably isn't a good idea. Adding gas to diesel lowers the lubricity of the diesel as well as the cetane number (Cetane is the inverse of octane) and is what allows diesel to ignite under pressure. Adding a substance with a high octane (Gasoline) to diesel fuel actually ####### the ability of diesel to ignite (Kinda the opposite of what one would expect) and at the same time gasoline raises the combustion temperature and decreases the lubrication which may cause certain wastes to cook in to the injectors. Then there are the emission issues.
    My bottom line is that the ratio you mention (1/100) likely would cause little if any problems and also likely it will be of little benefit. Higher ratios "could" cause problems and would be cost prohibitive as compared to commercial anti-gels. Therefore I do not believe it's a good idea.
    OEF08, johnday and lostNfound Thank this.
  5. Green Machine
    Green Machine Medium Load Member
    623
    175
    Jul 23, 2009
    Depending on what truck you have... watch what you burn in the tank. The DPF doesn't like certain things going through the fuel.
  6. karnage379
    karnage379 Light Load Member
    117
    11
    Sep 12, 2011
    lowell, MA
    newer trucks will not like this, ESP ones with DEF injection. Gas is much more corrosive, and will eat newer injector cups, which seal the inj to the head, causing it to suck air when intake is occuring. This will result in a stall if it is a large enough amount.
    OEF08 Thanks this.
