Anti Idle Shutdown device, how much trouble?
Discussion in 'Questions From New Drivers' started by Pariente, Feb 21, 2014.
  1. Pariente
    Pariente Light Load Member
    51
    23
    Jan 5, 2013
    Southern DE
    Ok I have a question but here's the deal. I didn't disabled the Auto Idle Shutdown but was able to work around it and made a device to let my truck idle for as long as I want. No high RPMs, no brakes released or anything like that.
    My question is: How much trouble can it cause? I know about some states not allowing Idling with fines but, what could happen if the lease company finds out about this little hack?
  3. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Unemployment
  4. Pariente
    51
    23
    Jan 5, 2013
    Southern DE
    I forgot to mention: The reason I use it is because I want the truck to warm up a little while I do my pre-trip and before getting out my personal car in the mornings. Also, at very cold outside temperatures it doesn't take long to freeze to death while taking a long nap. Sometimes I have to wait up to 3 hrs to get released from some of my stops.
  5. Lowa3468
    Lowa3468 Heavy Load Member
    889
    648
    Feb 10, 2014
    Portland, Or
    Unemployment I would agree
    2nd if you are going to want to idle for long periods of time you need at least 1k rpm? (Not sure the number but cruise control on and accel til it stood? hard on engine when idle isn't elevated.
    there also is a work around so your truck/qc won't register idling also.
    3rd do you have apu? If not I have heard that having no way to idle truck especially in extreme weather is against the regulations. Heard of a few at knight who went to dot and complained and company had to remove the automatic five minute shutdown
  6. Pariente
    51
    23
    Jan 5, 2013
    Southern DE
    Well I think that's for my company to decide but when I mentioned to my supervisor he said that he could care less as long as it doesn't screw something up on the truck.
  7. Pariente
    51
    23
    Jan 5, 2013
    Southern DE
    Thanks Lowa3468 I didn't know about the needed high RPMs for the engine, the very longest I have to wait once in a while is 2-3 hrs and the minimum 1/2 hr. I have tried the Cruise Control trick but still shuts off. I don't have APU since I'm home every day.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Qualcomm, yes... engine ECM, no.
    I know it can be set so that the idle shutdown only operates in a certain temperature range. Even on APU equipped trucks, this is often done because of the risk of gelling at low temperatures.
  9. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    You are leasing?
    Then isn't it your truck to idle? Your fuel to burn? Your expenses...
    Mikeeee
    gpsman and NavigatorWife Thank this.
  10. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    I'm sure the DOT has better things to do. No need to remove the timer, just enable the bypass.
    Pariente and Moosetek13 Thank this.
  11. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Maybe try working for a company that doesn't treat drivers like pigs.
    x#1 and WitchingHour Thank this.
