Antifreeze bubbling and leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Thetrucker8, Aug 13, 2024.
  1. Thetrucker8
    Thetrucker8 Bobtail Member
    I have to constantly refill my anti freeze every 2-3 days. Occasionally for a week it doesn’t need refilling. I have no idea where the coolant is going I can’t find the leak. My truck isn’t overheating. There is no anti freeze mixed with the oil as well. Do any of you have any recommendations on how to find the issue? Or will I have to play the guessing game which will require a lot of money.
  3. Ridgeline
    22,103
    113,210
    take it to the shop to see if it is a head gasket.
    Deere hunter, Cattleman84 and Concorde Thank this.
  4. Iamoverit
    Iamoverit Road Train Member
    1,539
    3,328
    Oct 31, 2023
    Get yourself one of those liquid coolant leak testers.
    https://www.harborfreight.com/combustion-leak-detector-64814.html
    Lav-25 Thanks this.
  5. Lav-25
    Lav-25 Medium Load Member
    536
    808
    Mar 31, 2018
    It might be related to how much your adding . Some newer petes have the full level about a inch below the cap and any excess goes out as overfill . I fill mine to bottom of cap - ( usually driving heavy , and in the heat ) , so i add more and by the 2-3rd day , top it off again . ( reasoning behind filling to the cap is that if its filled to full line by the third day low coolant light and full time engine fan ) . Might be the issue
    Iamoverit Thanks this.
  6. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,647
    15,955
    Jan 18, 2011
    You’re not gonna see a leak or any evidence of the leak it’s blowing out the stacks. My money is on a head gasket
  7. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Definetally sound like a head gasket to me.
    Deere hunter and Lav-25 Thank this.
  8. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Take the exhaust band clamp off the back of the turbo. Get a really bright flash light, see if you find what looks like silica sand particles the color of your antifreeze in the back of the turbo. When you’re burning minor amounts it turns to what looks like sand.
    Depending on what motor you have and if it’s pre egr it’s most definitely a head gasket or pin hole in liner type problem. If it has egr it could be a bad egr cooler. If it has a bad cooler disassembly and inspection usually reveal it. I have found many a bad precooler on acerts by lookin in the hole
  9. Lane=addict
    Lane=addict Light Load Member
    62
    59
    Aug 12, 2024
    Is this a newer style Paccar mx, or Cummins x15 with the weird shaped plastic surge tanks? Are you getting a low warning light on dash often? And checking the tank level looks good. The newer style surge tanks are a throw away part. You get a new surge tank with level sensor for about $350. The surge tank service life is about 300,000 miles. Just my experience as a driver not a tech.
  10. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    what engine and chassis
  11. beastr123
    beastr123 Road Train Member
    2,803
    22,846
    Jan 2, 2014
    Moose Jaw SK CAN
    drain your air tanks
    the air compressor is coolant cooled
    BoxCarKidd Thanks this.
