I have 2009 freightliner Columbia that is building up air pressure in the antifreeze tank, The tank is brand new as is the egr cooler , there some black substance appearing in the tank , I have to add antifreeze everyday but check engine light still turns on after driving for a while . There is no antifreeze leaking from anywhere , what can be the problem?
Antifreeze tank pressure build up
Discussion in 'Ask An Owner Operator' started by Arod003, Jun 3, 2019.
No antifreeze in engine oil or transmission oil
Oil in the radiator, black dots, sludge
Cracked hose if no pressure does it smell of antifreeze in cab,. Heater core
Do this ...
Go and get the coolant system flushed and change the radiator cap.Farmerbob1 Thanks this. -
Will try that thanks
What motor? If oil is in coolant the 2 prime suspects are head gasket or oil cooler. Oil pressure is greater than coolant pressure so oil in coolant is the first sign.
Farmerbob1 and RockinChair Thank this.
