Any advantages 0f a 13 speed?
Discussion in 'Questions From New Drivers' started by bamamac, Mar 10, 2013.
  1. bamamac
    bamamac Medium Load Member
    671
    282
    Nov 4, 2010
    Alabaster,Alabama
    Just curious to know if any of you that drive a 13 speed like it and prefer it over others?
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    I think anyone who has driven a 13 will much favor that over a typical 9 or 10 speed.
    Raiderfanatic Thanks this.
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    a 9 spd is a 13 without the gear splitter OD.
    The 9 spd is the most fuel efficient tranny made for the manuals.
    Splitting gets you better control for the hills.
    For a road truck and most other conditions, the 13 is fine. If you get into heavy haul, consider the 18 for splitting the bottom side too.
  5. cc tanker
    cc tanker Medium Load Member
    361
    214
    Jan 21, 2011
    13 gives you the ability to get 1/2 a gear at atime better for fuel mileage better for pulling all around a great tranny ..no need to split all of the time I still skip alot of gears when empty but when loaded esp in hilly areas its the cats meow..
  6. jbatmick
    jbatmick Road Train Member
    2,198
    2,507
    Dec 1, 2009
    hastings, Fl
    My favorite transmission.:smt049
    DriverToBroker, crb and Raiderfanatic Thank this.
  7. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    9spd isn't necessarily most fuel efficient. Technically a direct drive is more efficient. Fuel economy depends on much more than transmission! 13 spd is nice because you can split top gears for hills or drive it like a 9 spd. Transmission needs to be matched to the right rear end for max fuel efficiency.
  8. Trashtrucker1265
    Trashtrucker1265 Road Train Member
    1,310
    944
    Dec 14, 2009
    Inverness, Fl
    I drive an 18 speed here in western PA and I wouldn't have it any other way, to be able to split each gear really helps me when I'm loaded starting off on inclines. Being able to split each individual gear makes the gear change much quicker, and really no lag like you would have in 8-9-or 10 speeds while pulling a grade. I'm originally from Florida and I see no need for it down there, a standard 10 was always fine for me, so I guess you could say the preference really will fall within where you operate.
    aiwiron Thanks this.
  9. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Yep. A 9 speed is only more fuel efficient if you govern the truck down to not need overdrive. Knight did all the research on that years ago (when fuel was $1 a gallon). I personally would rather sacrifice 0.3 MPG to go 8 MPH faster (with 3.55 rear gear & 24.5 LP tires). Even at only $1.11 per mile line haul rate you are at break even, at $2 per mile you are earning way more money. $16 per hour more pay while spending $9 per hour more for fuel = $7 per hour more revenue with a 13 Vs. a 9 speed.
  10. Trucker Bug
    Trucker Bug Light Load Member
    117
    86
    Jan 24, 2013
    California
    Rather have a 13 simply for the hills. You have more options and can drop Or grab a half gear at a time instead of a full saving speed.
  11. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    Eaton 13 speed is a nice transmission.
    I was assigned a new Volvo in January with an iShift 12 speed automatic and don't care if I ever go back to manual shifting though.
    chopper103in Thanks this.
