any info on johncox trucking in avon ny
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by plater1, Aug 8, 2011.
  1. plater1
    plater1 Medium Load Member
    341
    241
    Jan 24, 2011
    back in NY
    they are hiring, but i can't find any info on them. any help would be much appreciated.
  3. groundpounder
    groundpounder Road Train Member
    2,569
    1,039
    Nov 13, 2009
    You must have seen the craigslist add, yes ??
    I called and talked to David last Friday they run mostly short regional type stuff even though the add says OTR...
    He said they do have some longer runs that go down south but the bulk of it is short stuff, back hauls come back to Rochester, Buffalo, and the 'Cuse...Average length of haul was around 350 miles he said..
    Call him he will fill you in..
    plater1 and 123456 Thank this.
  4. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,289
    Dec 15, 2008
    Rochester, NY
    Look into Bartlett Dairy in Rochester.
    They service the Starbucks stores around WNY.
    $18.00 with OT, home every day
    A couple of downsides is they work at night, food service(very labor intensive), a very odd rotating schedule,
    Also Palmer Food distribution
    Also food service, lots of hard work but $15-$17.30 an hour DOE
    123456 and plater1 Thank this.
  5. plater1
    341
    241
    Jan 24, 2011
    back in NY
    yes, i saw the craigslist ad. i stopped in today to get an app and spoke with david. i was curious if the had any problems. i was a little turned off when he said they do per diem.
  6. groundpounder
    2,569
    1,039
    Nov 13, 2009
    I was turned off by what appears to be lack of miles when his add read like it was an OTR job..
  7. plater1
    341
    241
    Jan 24, 2011
    back in NY
    thanks for the info everybody, i think i'm going to pass on this job.
    123456 Thanks this.
  8. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    i know they pick up out of a place west of rochester called allen canning in brockport.... i see quite a few of there drop trailers in there...
  9. plater1
    341
    241
    Jan 24, 2011
    back in NY
    if it's the place by the canal, i've picked up there for shaffer.
