Any info on Sunset Logistics in TX
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by korky, Aug 16, 2013.
  1. korky
    korky Light Load Member
    97
    56
    Aug 14, 2013
    AZ
    Does anyone know anything about Sunset Logistics out of Dallas/San Antonio? Looking to move to either of the cities from AZ and they look like they pay O/O's pretty well. I am a driver now but looking to buy a truck and am looking to run end/belly dumps. Any other co's in TX that are good to run for? Would consider flatbed also. Any info would be greatly appreciated. Thank you.
  3. teqntexas
    teqntexas Medium Load Member
    689
    547
    Jan 25, 2012
    Ft. Worth Tx.
    can't really help ya alot there driver just that i see them allover here in Austin as well, they seem to be doing a ton of work with the toll road construction around here. good luck to ya.
  4. haulintx
    haulintx Light Load Member
    57
    6
    Dec 5, 2012
    Waxahachie, TX
    I worked for them for a few weeks. Dont believe the $$$ they claim you will make. I ran every single run assigned and brought home 400-550 a week as a company driver. But as a O/O it may be differnt.
  5. korky
    97
    56
    Aug 14, 2013
    AZ
    Update: The boss lady is leaning towards Dallas. Can an O/O actually make the $5000 per week that Sunset Logistics advertises on CL? Are there any good co's to run for in Dallas? I prefer end/belly dumps but have many years runnin flatbeds. Thank you for any info.
  6. haulintx
    57
    6
    Dec 5, 2012
    Waxahachie, TX
    I would catch one of their o/o out and about and chat with them. The money they promised as a company driver was BS. I hope it works out for ya.
  7. gasmonkey
    gasmonkey Bobtail Member
    Just curious if you ever found out about sunset
  8. YungtruckingN14
    YungtruckingN14 Bobtail Member
    Oct 21, 2014
    Sunset was real bad about sending checks on time, And you never gross more then 3500 for each truck fals advertising 5k or 6k gross i had 3 truck running under my own authority not lease. But the stop doing brokers and only lease. They are also bad about answering phone calls when you need to contact them and they always changing manegers and dispatch
    korky Thanks this.
  9. ozaguilar
    ozaguilar Bobtail Member
    8
    YungtruckingN14 , did you run out of Fort worth terminal?
  10. ozaguilar
    8
    Korky , did you end up working for sunset logistics?
  11. korky
    97
    56
    Aug 14, 2013
    AZ
    Plans for a Texas move are put on hold for now, but I would still like some info on Sunset Logistics if anyone can help. Drivers side or O/O side.
    Thank you
