I'm going to haul something that is around 15' 10" in height. I'm pretty sure this is well under anything I'll come across, but I'm trying to make absolutely sure. I can't find anything online and the ports told me I'd have to come in before they can tell me details about anything...I'm not really a trucker, this is with my personal pickup so I'm not exactly sure where to find this info. I thought maybe someone here could help me out.
Phoenix to Houston on the I10. I'm good right?
Thanks for any info!
Any low clearance on I10 in AZ/NM/TX?
Discussion in 'Trucking Industry Regulations' started by BEETR00T, Aug 18, 2012.
TRKRSHONEY Thanks this.
14 feet is legal along your route, but past Tucson but before the exit for 302 you will not be able to get under the bridge before the exit. You need a route survey done and certified.
TRKRSHONEY Thanks this. -
You could call the over sized permits offices in those states and give them your route. They should be able to tell you if there are any overpasses that will cause you a problem.
aiwiron Thanks this. -
you wont get under the Benson bridge. I-10 AZ...
You need an oversize permit!!!!!!!!
i believe that is a RR bridge in Benson, no ramps. Houston can get you into trouble fast. You can not go thru on 10.aiwiron Thanks this.
