Any Proplem with 42,000 Lbs
Discussion in 'Ask An Owner Operator' started by iland300, Mar 27, 2015.
  1. iland300
    iland300 Bobtail Member
    32
    Apr 20, 2014
    Hello Truckers,
    Happy week where ever you are trucker and may God bless us all for the hard work we do, I haul 20/40/53 feet containers in the Midwest, every week I get like 42,000 lbs. Do I expect Any problem for the Engine. My Truck is Freightliner Century with 60 series that did super over hall mainly in the engine, transmission and the wirings.
    Regards,
    iland300
  3. dog-c
    dog-c Road Train Member
    1,852
    1,546
    May 30, 2011
    New York, NY
    Check your oil samples
    60 series is a good reliable engine
    what specifically are you asking ?
    iland300 Thanks this.
  4. iland300
    32
    Apr 20, 2014
    I always haul two times a week weight about 42000 lb, is it ok for my truck and engine or refuse to haul the above heavy load as a new owner/operator.
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    42k does not really mean anything without knowing your mt weight or type of trailer or anything like that. but really if your under 80k and it pays good enough i would not sweat it
  6. CruisingAlong
    CruisingAlong Medium Load Member
    374
    441
    Oct 17, 2014
    Tampa , FL
    I'm not an owner operator, but your truck was designed to do it. I'd rather haul 42 or up to my maximum 51700 (my truck/flatbed trailer combo is 28300lbs full of fuel) over relatively smooth roads than 10k over rough pothole riddled roads.
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    All else equal, if an engine grossing 80,000 lb lasts 1,000,000 miles, I'd expect an engine grossing 60,000 lb to last 1,070,000 miles and get 7% better fuel mileage. Price accordingly.
    iland300 and icsheeple Thank this.
  8. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    42,000 isn't a lot in the trucking world, most loads are closer to 45,000 or more. As long as you keep your oil and coolant clean and full you should be fine, watch the temp gauge the more you haul and the harder you haul it the hotter it will run that is also normal, however if it gets hot enough to light the warning light or sound the alarm something is mechanically wrong,(not the 42,000) 42,000 is not considered a full load where I work, you have to be able to "legally" haul 46,000 or they won't lease you on.
  9. superflow
    superflow Road Train Member
    2,038
    1,870
    Jan 2, 2014
    60 series are a great engine, .... 42k will be a fuel sucker load, I've never pulled any sea cans myself but had friends tell me it's hard on their equipment, not sure exactly why .... I know you have to watch the chassis clearance when back into deep well docks sometimes the chassis will bind up on the trucks chassis.... Atleast you don't have alot Hills out that way.....
    ....... Bless you back
  10. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I could haul up to 47,500 when I drove a '98 Pete 377 with series 60 detroit pulling dry van. Oil samples always came back clean.
  11. kor b
    kor b Light Load Member
    254
    103
    Dec 16, 2008
    The typical class 8 truck with most trailers is just fine with a load 42,000lb.
