Any tips on getting the true height of your rig?
Discussion in 'Questions From New Drivers' started by JoeF2002, Jul 24, 2016.
  1. JoeF2002
    JoeF2002 Light Load Member
    165
    119
    Dec 31, 2015
    Saylorsburg, PA
    Hey gang - I'm confident this question has been asked before, but I haven't been able to find much on it. What recommendations do you have for getting the truest height measurement of your rig? Things that come to mind for me include:
    a) parking on level / paved ground
    b) starting up the truck / idling it for a few minutes to pressurize system
    c) low amount of diesel in the tank (figured the more diesel it has, the lower the ride height)
    d) remove all accessories that are used regularly from the truck (e.g. winter chains)
    e) make sure no one is sitting inside when you measure
    f) disconnecting / pulling away from the trailer (if the only concern is about cab height and not trailer height)
    What else am I missing? Any suggestions?
  3. sawmill
    sawmill Road Train Member
    3,700
    68,646
    May 29, 2015
    Evanston, WY
    I don't think you need to remove anything or run the tanks low. The air suspension leveling valve will keep it at the same height no matter what. Just make sure you start it up and let it build air. Then measure from the highest point, usually the tip of the stacks.
    tscottme, rabbiporkchop and JoeF2002 Thank this.
  4. iRookie
    iRookie Light Load Member
    140
    174
    Aug 16, 2015
    Try this method or get a laser measure
    tscottme and JoeF2002 Thank this.
  5. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    The only thing that really matters is that you have the truck started and the air suspension inflated. It self-levels, so you don't have to worry about weight on it.
    tscottme, JoeF2002 and MrEd Thank this.
  6. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    All of the above, but would only add, measure it while sitting on a scale... they are a sure way to guarantee everything is as level as you'll find.
  7. MidWest_MacDaddy
    11,192
    18,878
    Feb 21, 2015
    South Carolina
    Seen a similar method but didn't use the arm reach nor moving the body to adjust to the tree... But looks a bit easier if only one person too... I still like the laser option best... :)
    JoeF2002 Thanks this.
  8. coueshunter
    coueshunter Heavy Load Member
    728
    432
    Nov 23, 2014
    Why do you need the exact height?
  9. MACK E-6
    49,023
    227,616
    IMO it's part of a driver's job to know those things.
    MJ1657, Roberts450, TripleSix and 2 others Thank this.
  10. MACK E-6
    49,023
    227,616
    Empty trailer too, especially if you're running spring ride equipment.
    brian991219 Thanks this.
  11. coueshunter
    728
    432
    Nov 23, 2014
    For what reason? If your close your good enough. There will be more variances in the road versus going with 13' 13'6", 14' etc...
