Anybody have a tabletop icemaker?
Discussion in 'Experienced Truckers' Advice' started by JC1971, Feb 24, 2019.
  1. JC1971
    JC1971 Road Train Member
    2,673
    9,789
    Jul 29, 2013
    Southwestern U.S.
    Anyone have one of these and happy with it? Can't have a refrigerator, won't buy another POS 12V cooler, and tired of buying ice.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    You will find a number in stores like Lowes etc. Around 110 dollars for the small ones off 120 volts and take about a pitcher of water and make ice in a hour or so. You would have to precool it a hour prior to. You cannot have it blocked in or otherwise working with no airflow around the sides.
    So call it a gallon of water, two hours of inverter time and that should come up with pretty good ice for your day.
    Make sure the ones that do not require a water line connection. Just a pitcher of water usually. And of course in winter you just need a few ice trays and set em out on the cat walk a few hours and wait.
    JC1971 Thanks this.
  4. Ridgeline
    22,630
    120,506
    Yeah I have one in the kitchen, my fridge doesn't have an "ice maker" because it was made in 1935 - Frigidaire custom made thing I pulled out of a huge house in Detroit.
    It isn't much to look at, it takes a little over one cubic foot and is heavy. It is a power hog, prone to have the ice dropping mechanism fail because they are fragile.
  5. Numb
    Numb Crusty Curmudgeon
    4,231
    9,935
    Jan 30, 2012
    Charlotte, N.Carolina
    I usually got about 2.5 yrs out of the 12V coolers.
    using points , they ran me about $50. you can buy lots of ice for that.
    keep the vents clean and not blocked.
    and I idled so the ambient temp in truck never got to high.
    JC1971 Thanks this.
  6. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    Yea I do.
    Best purchase I made for the truck even though I do have a good size built in frig and freezer in my Western Star but I like ice in my soft drinks and water.
    It’s a Frigidaire unit I bought from Lowes.
    Held up real well so far for bouncing around in the truck the past 8 months.
    Started to act up last week. I thought the bouncing and the inverter cutting in and out on bouncy roads because of a bad plug did it in.
    Inspected it and seen it was really stained from hard well water getting ran through it
    Ran some vinegar through it and flushed it and it works good as new again.
    Actually had to buy a couple bags of ice while it was acting. Forgot what a pain that was.
    JC1971 Thanks this.
  7. tscottme
    tscottme Road Train Member
    fyi, I replaced my 20 year old 12v Igloo with a 12v Coleman. It's a struggle to keep my contents from freezing. My last cooler never got as cold as my new cooler.
    JC1971 and ZVar Thank this.
  8. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    When the motors or fans go bad on the 12V coolers, you can buy replacements online for a few bucks. I've never done it, but I've seen the replacements online many times, and they drop in with 4 screws.
    JC1971 Thanks this.
  9. JC1971
    2,673
    9,789
    Jul 29, 2013
    Southwestern U.S.
    The problem with the 12 V coolers is the cold air sinks and freezes stuff at the bottom of the cooler. Also, items placed next to the fan will freeze. During hot months, it's a struggle to keep food at food-safe temperatures. The obvious solution is to get hired on with a real company that has APU's but in the meantime I think that ice is the best solution as much of a PITA it is.
    tscottme Thanks this.
  10. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    I always just had mine laid down horizontal. The only issue I had with temp is placing the milk next to the fan. After a couple days I had to move it to the other side to prevent freezing.
    No my main issue was the plug overheating. In the year I was OTR I had to replace it twice on my Coleman.
  11. GreenPete359
    GreenPete359 Road Train Member
    2,179
    5,194
    Oct 21, 2017
    Driving my recliner
    Fify;)
    JC1971 Thanks this.
