Anybody running Linux?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by volvo244t, Dec 31, 2013.
  1. volvo244t
    volvo244t Road Train Member
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    I just acquired a free dead 2,1 (white, mid-2007, core 2 duo, etc.) macbook and made it undead. That's right, I'm using a macbook zombie! MUAHAHAHAHAHAHAHA!
    Anyway, I tried to install Snow Leopard to no avail, and I didn't want to install Lion, because it's a bit bloaty for a machine this old. So I downloaded the Ubuntu 12.04 LTS live CD and installed that. And Windows has gotten nearly impossible to pirate, but that's the only way to get Win7 now as sales have ceased, and I have no interest in Win8.
    I'm wondering if anybody is in a similar situation, OS-wise, and has tried running the Transflo Now application under Wine. I've already determined that my printer/scanner will work, so that's no issue. If not, it's no biggie, I'll just replace the cracked screen in my Win7 netbook and use that for transflo, but it'd be nice to have a one-stop shop.
    Thanks in advance everyone.
    And a side note, despite the price, the operational status when I got it, and the age - this is actually the first decent laptop I've ever owned. After tossing 4GB of ram in it (came with 1GB), it works almost as well as my AMD quad-core desktop. The overall speed is actually pretty much the same, but the graphics are laggier, as is expected with a laptop, especially an older one. Toss in the fact that my desktop has a GTX 460 graphics card and it's no-contest. In any event, Intel knew what they were doing when they came up with the Core 2 Duo, that's all I can say.
  3. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Give the same situation I would run XP in virtualbox. It's how I run my DDL installation, since you can only relicense DDL 3 times and I change hardware more than that.
    RedForeman Thanks this.
  4. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    I run Win7 in a Parallels VM on my Macbook Air for Eclipse logs and anything else that's Windows only. So a +1 on a virtual machine strategy.
    I quit bothering with Linux distributions. Too fiddly for my taste. I got tired of installing stuff that required a lengthy search for all the supporting software modules that also wouldn't work for some reason I had to figure out. Wine is a pita all on it's own.
    Put an SSD in that old Macbook and you'll be surprised all over again. My previous laptop was a 2008 MBP. Adding a solid state drive made it brand new all over again. Say what you want about Apple, they do make a fine laptop.
  5. volvo244t
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    Linux has come a long way in the last couple of years or so. And I do mean a LONG way.
    As for Apple, I'm 'fraid I have to give more credit to Intel, here. The Core 2 Duo was and still is a #### good processor. This thing gives my desktop a run for its money in almost all areas except graphics, as mentioned in the OP, and the desktop is 3 years newer, with an AMD quad-core 3GHz processor. And while this laptop 4GB of RAM installed like the desktop, it can only use 3GB of it, due to the limitations of this particular chipset. So, the desktop is 0.86GHz faster per-core, with two extra cores, and one extra usable GB of RAM. It should absolutely blow this thing away, but instead, it barely edges it out. I used to be an AMD nut, not so much anymore.
  6. RedForeman
    4,875
    22,141
    Jan 30, 2011
    AMD processors have always lagged behind Intel on most everyday computing tasks. Their strength is in floating point operations, which typically support graphics intensive stuff like gaming.
    Processor speed isn't the bottleneck in most computers any more - it's the data busses choking things down now. Mainly the relatively slow read/write speeds on mechanical hard drives and slow rates on USB 2.0 or earlier.
    ETA: The strength of Apple hardware is the thing everyone loves to complain about. Proprietary, standard construction. The good part is that they use better than average parts carefully integrated. The main reason I like Apple hardware (computers especially) is that they tend to just work. Never the best in class performance-wise, but generally rock solid reliable.
    My 2008 MBP finally expired with a motherboard fault after three years of frequent travel with hundreds of trips through TSA airport security bins. I had upgraded to a SSD, and later had to replace the cooling fans. Oddly, it died after a couple months at home running stationary on my desk. As careful as I am, I feel the motherboard failure was probably a product of me disturbing it's guts changing drives and fans over the years more than anything else.
  7. jpflumignan
    jpflumignan Bobtail Member
    11
    Long Island , NY
    I had a dual boot PC before I got a Microsoft Surface RT. it wasn't pretty, simply put because 250GB's is a huge downgrade from 1TB. it was sluggish, to say the least(all this because I needed a computer for school, and was too lazy to register my windows pc)
  8. Wolfyinc
    Wolfyinc Road Train Member
    2,888
    969
    Apr 21, 2013
    Salem, or
    linux has indeed come a long way and is a lot more user friendly today for those people out there who dont know how to even use it. I remember back when I first started using linux there was no one click install....
    I havent used linux in a couple years but I have thought about setting up a dual boot with my laptop and installing back track to get me some wifi in places...
    when you tried installing the snow leopard what happened?
  9. JPenn
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    I'm currently a fan of the Linux Mint distribution. Used most of the majors and a few of the minors, but this is the one I'm on currently. Of course, I've got to echo RedForeman's feedback on Apple in general. I've had a few, and only had age related problems with them. Currently on a '12 MacBook Pro, finally had to give up on my TiBook after the display hinges cracked.
  10. Wolfyinc
    2,888
    969
    Apr 21, 2013
    Salem, or
    I want to get a mac but got more important things to pay for, wife also wants to get a bigger house soon and an suv...
    I have an older laptop I bought in 2011 but it still runs strong, 17inch screen, 4gb ram, 500gb hdd, blu ray with hdmi out and its an AMD. I have always been a fan of AMD since the beginning, I did just replace my battery this past week since the other died and as long as it keeps running for me I wont be buying anything else for another year or so.
  11. Ridgeline
    22,603
    120,016
    I use a lot of different flavors of linux. I am using on this box ubutu with KDE on top of the OS. It isn't hard to install now, actually the last install I did was a lot easier than the latest windows install I did.
    About apple, there is a lot of negative over the development of software for ios and OS X, one of the things I do feel they should have been treated like Microsoft and the issue of forced bundling. I won't get into the way they have their marketing and sales contracts setup, it is really closed market.
    However their hardware is no longer proprietary, they moved form risc to intel and if one is inclined to build a hackitosh, it isn't hard.
