Anybody Work For Haliburton (San Antonio)
Discussion in 'Oilfield Trucking Forum' started by DevJohnson, Sep 2, 2018.
  1. DevJohnson
    DevJohnson Medium Load Member
    340
    153
    Nov 27, 2017
    So I know there's a lot of companies they will hire in the fields (hoping me say the keyword 'fields' doesn't get this moved) and was wondering if the position Operator Assistant would mean you'd be driving truck sometimes? It ask you to get your CDL with tanker endors. so I figured it might. I'd have to call Tuesday but figured this might be faster so I know.
  3. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,030
    Dec 31, 2010
    Washington, PA
    I believe OA is a frac hand. Which means you will drive occasionally, but your main job is working the frac pad.
  4. JoeyJunk
    8,763
    68,030
    Dec 31, 2010
    Washington, PA
    However, I’m speaking only for the Northeast. They may do things differently in SA.
  5. HillbillyDeluxeTruck
    5,902
    30,210
    Mar 3, 2013
    San Antone
    99% sure haliburton requires you to have a cdl when you work for them in the event you might have to drive a truck.
    Lav-25 Thanks this.
  6. DevJohnson
    340
    153
    Nov 27, 2017
    I have one
  7. HillbillyDeluxeTruck
    5,902
    30,210
    Mar 3, 2013
    San Antone
    I guess I read your question wrong. Are you not wanting to run a truck at all and just work on site?
  8. DevJohnson
    340
    153
    Nov 27, 2017
    Correct. Idk why they say to have a CDL or they will help you get one. I already have one and have driven truck. I'm calling tomorrow
  9. HillbillyDeluxeTruck
    5,902
    30,210
    Mar 3, 2013
    San Antone
    Because they have a lot of equipment on site that gets trucked in and out. If every employee has a cdl, then they dont have to worry about a worker not being able to legally operate a truck.
  10. Paddlewagon
    Paddlewagon Light Load Member
    278
    264
    Sep 17, 2017
    Llano Estacado
    .............precisely,your most important quality to Big Red will be a strong back and the ability to swing an 8# sledgehammer.
  11. Seattle206
    Seattle206 Light Load Member
    293
    119
    Oct 17, 2011
    Halliburton Structure is as following!
    Every Department in Operations starts you out as an Operator Assistant, and after 9 months of employment you go to Operator Assistant II; and after that things are based on your knowledge of the equipment you operate or should know how to operate via a computer test to make Service Operator I @ that level you qualify for annual raises. Then its Service Operator II, and finally Service Supervisor I
    I worked there for about 4 years before getting laid off back in 2015
    Desert_3agle Thanks this.
