anyone able to help 5th alternator in e months
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rj1981, Mar 15, 2012.
  1. rj1981
    rj1981 Bobtail Member
    15
    7
    Sep 19, 2010
    Kane, PA
    Ok I have a 2002 international 9900 with a Cummings have replaced the alternator5 Times in the last month I have a normal draw only essential lighting and a small 300 watt power inverter that runs my printer and laptop it only gets turned on for a couple hours. Thats all I have drawing power the batteries were replaced twice all 4 please I need ideas
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    What size alternator are you using and what capacity batteries do you have? Does you truck have any kind of low voltage protection? What does your voltage show when the truck is running?
  4. rj1981
    15
    7
    Sep 19, 2010
    Kane, PA
    Its a 160 amp with 4 940 amp deep cycle batteries when alternator is working I run 13 to 13.5 volts. Don't think it has low voltage protection last time it went out i decided to take it to international dealer by time I got it there everything was gone except for engine even gauges stoped working. When alternator goes bad voltage drops to 12 12.5 this I is per gauge and voltage meter attached directly to alternator.
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    13 to 13.5 OS to low should be running 14.5 are the altanators rebuilt? I would check all the connections and grounds have you checked the output at the altanator?
  6. rj1981
    15
    7
    Sep 19, 2010
    Kane, PA
    14.4 at alt 14.2 at bat.
  7. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Cell test your batteries.
    That's low voltage. Why?
  8. Hardlyevr
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    for your voltage to be that low, you either have had a slew of bad alternators, or the wiring connections to the alternator have a problem, or you have a humdinger of a dead short someplace else. At the very minimum you should have 13.8 when running, or more likely 14.2.
  9. rj1981
    15
    7
    Sep 19, 2010
    Kane, PA
    The gauge on dash reads 13 to 13.5 volt meter attached to alt shows14.4 at bat 14.2 alt is New no rebuilds batteries test good
  10. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Check for voltage drop going into cab with a voltmeter.
  11. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Id rewire everything if I was you. Sometimes when testers test with pin pricks going thru insulation, it causes all kinds of problems from moisture corrosion, etc.
