anyone doing hotshot with a swd truck legaly
Discussion in 'Expediter and Hot Shot Trucking Forum' started by wedge542, Sep 6, 2014.
  1. wedge542
    wedge542 Light Load Member
    241
    31
    Aug 13, 2007
    roll tide
    if your useing a swd truck to hotshot and you go across scales id like to know your sticker numbers on your door, mainly fords, i got a 05 f250 and seems ill be outa weight with just the trailer almost and it only weighs 5600lbs tri axel.
  3. stammingerr
    stammingerr Bobtail Member
    39
    5
    Aug 6, 2014
    just because the trailer is 5600 lbs doesn't mean it puts 5600 lbs on your rear axle
  4. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    lol, yea i know, but dot telling me theres no way in the world i can get legal with my current setup at 10000 payload on the trailer
  5. stammingerr
    39
    5
    Aug 6, 2014
    Really? As long as you position your load right I would think it could be done, just my opinion.
  6. Nedrudt
    Nedrudt Light Load Member
    224
    44
    Nov 10, 2013
    Tucson, Az/Dublin, Oh
    I've seen some srw f350s and dodge 3500s pulling 40's in Louisiana but no f250s. Anything is possible. Oh and every dot officer is different, and just like everyone else some people are good at their job and other need to go back to the drawing board.
    LGarrison Thanks this.
  7. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    he says ill run out of truck before trailer, trucks sticker says 9600 gvwr but all brochures-adds-even on fords site say 12000 with a 23000 gcwr, right now i just bought a slider 5th wheel and it goes foward about 6 inches ahead of center so ill load a truck on it and go to the scales and see, i can legaly put 4850 on the steer and 6100 on the drive to keep legal.
  8. Lite bug
    Lite bug Road Train Member
    1,406
    30,969
    May 3, 2014
    Columbus Ohio
    That 9600lbs on the truck is going to be something you will always be something to be concerned about.
  9. Nedrudt
    224
    44
    Nov 10, 2013
    You'll be suprised but the trailer takes about all the weight. I run at 26,000 every time I'm loaded and I've never had to worry about the drive being over weight. It is a lot about load placement though, don't get me wrong.
  10. wedge542
    241
    31
    Aug 13, 2007
    roll tide
    NED, can you tell me whats on your door sticker as the gvwr at the very top then the steer and rear?
  11. Tanhands
    Tanhands Light Load Member
    83
    22
    Aug 1, 2014
    Gilbert, AZ
    Wedge I had Airbags in my 08 F250 and it essentially gave me a 1 ton rear axle weight. Not sure what the DOT would say about it as it is not in the door sticker that way. I traded the F250 for a Dodge dually so I am not sure what the door sticker said.
