Anyone have a good used 13 spd trans?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Andrew Woods, May 6, 2019.
  1. Andrew Woods
    Andrew Woods Light Load Member
    78
    24
    Feb 22, 2016
    Pawnee, TX
    As title states, I am looking to swap my super 10 for a 13 spd. I would also be willing to trade plus some cash for mine. Is it possible to convert my super 10 to a 13 spd or any other higher speed? I mainly just want a couple extra gears up top.
    jamespmack Thanks this.
  3. wore out
    wore out Numbered Classic
    16,767
    205,228
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    A super 10 is .74 overdrive final ratio. A 13 depending on model is .87 final ratio if an old noisey RTO. An RTLO 13 or 18 is .73 final ratio. The only gain will be the super 10 jumps from 1.1 to .74. A 13 or 13 goes from 1.1 to .87 to .73.
    With no core your looking at 4500.00 just for a 13 speed. Finding someone to even give a little credit on the super 10 is about impossible. Buy the 13 outright get it put in then sell the super 10 and recoup what you can
    rank, jamespmack, BoxCarKidd and 6 others Thank this.
  4. Andrew Woods
    78
    24
    Feb 22, 2016
    Pawnee, TX
    Thank you for your help! What do you think the super 10 would be worth?
  5. wore out
    16,767
    205,228
    Jun 5, 2013
    Honestly I see them advertised 1500.00 to 2000.00.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Anywhere from 700 to 2,000 is what I've seen them for, they're not exactly a highly wanted trans to 90% of the people I know of.
  7. Andrew Woods
    78
    24
    Feb 22, 2016
    Pawnee, TX
    Thanks guys, gives me a little guidance to start with anyway.
  8. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I’ve got one up here in Pa. it’s in an 05 Volvo day cab. Buy the whole truck for $5000.
    rank and jamespmack Thank this.
  9. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I've seen this list of reman transmissions and differentials offers at Tri State Volvo in Little Rock ,AR off I-40. I have Eaton 13 also, I was curious and checked the price , aprox 3500$ part only with warranty .These are like new, ive been told are remanufactured by Eaton.
  10. wore out
    16,767
    205,228
    Jun 5, 2013
    That price is with a core. With no core to trade in you can add 2500 to 3500 to that.
    rank, jamespmack, Johny41 and 3 others Thank this.
  11. Hammer166
    7,575
    27,616
    Aug 18, 2007
    ~8600+' and loving it!
    Super 10's are basically 13 speeds missing some gears in the main and a lot bigger jump in the splitter. But I'd bet they share little but case dimensions. Without going thru the parts list, best guess is you'd likely have to buy all the internal parts (including shafts) of a 13, and at that point you're probably well beyond the cost of a reman.
    Andrew Woods and Johny41 Thank this.
