Anyone have any advice for a student on straight line backing?
Discussion in 'Questions From New Drivers' started by Spacat1, Jun 1, 2015.
  1. Spacat1
    Spacat1 Light Load Member
    80
    11
    Oct 13, 2014
    In my second week of CDL school but first week and first day of actual maneuvers, and I seriously struggled. No matter how many times I tried I could not back in a straight line. Anyone have any advice? Seems like I kept overcompensating way too much, and never could judge when my truck was straight.
  3. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    Calm down. You'll be fine. Nobody got backing down immediately. But back slowly. Watch your trailer and make slight adjustments while backing.
    Spacat1 Thanks this.
  4. tinytim
    tinytim Road Train Member
    5,143
    18,181
    Oct 29, 2007
    Northern Ontario
    Stop overcompensating. :)
    Make sure you mirrors are properly adjusted. It's hard to know if you're straight when the mirrors are messed up. As soon as you see it start to drift then turn into it. You know you're turning too far and overcompensating so turn less.
    It really is that simple but it does take some time to get used to. It's normal to overcompensate at first. It takes a bit of time for it to come back when you make a correction and when it doesn't come back immediately people tend to turn the wheel more, overcompensating.
  5. Spacat1
    80
    11
    Oct 13, 2014
    Thank you for the reassurances, I guess it didn't help that there is only one other guy in the class and he drove trucks years ago, so he hopped right in and backed it right up straight. I was all over the place though, and for whatever reason couldn't duplicate the few times I did it right.
    tucker Thanks this.
  6. Cat sdp
    Cat sdp . .
    20,920
    72,615
    Apr 8, 2012
    Orion's Belt
    Put one hand at the bottom of the steering wheel. And sit back in the seat and look in the mirrors which ever way you want the back of the trailer to go move your hand that way.......
    Fatboy42, Pmracing and Spacat1 Thank this.
  7. XCELERATIONRULES
    XCELERATIONRULES Medium Load Member
    492
    492
    Dec 29, 2014
    Watch both mirrors.if your tandems dissappear in a mirror ,steer to where you see the tandems,then countersteer for a second,losing the tandems is an early indication,your off track.waiting too long to correct will require greater input.Dont forget counter steering!
    If you sumply make a correction without counter steering,youll be off track again,in a few moments.
    Eric Rodriguez, enicolasy and Spacat1 Thank this.
  8. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Little movement on the wheel transmits to big movement in ###. Dont get impatiant waiting for the tail to move, alot of time people over correct becuse they turn the wheel and the trailler dosnt imidetaly respond. Its not a strait peice of metal, it takes a sec for your tractor to actualy start changing the trailers dirction.
  9. texasbbqbest
    texasbbqbest Road Train Member
    1,088
    1,962
    Dec 9, 2014
    Minneapolis, MN
    You'll be okay.
    What I did in school was I put my hands at the 9 and 3 position then when correcting only turn the wheel to where your hands are at 12 and 6 in either direction.
    That way if you mess up, you are only off about a foot.
    I hope that helps!
  10. camionneur
    camionneur Road Train Member
    1,239
    759
    Oct 18, 2013
    Try using the clutch intermittently to control momentum while getting your head around the steering.
  11. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    If you are having troubles with your hand on the bottom of the wheel, then put 3 fingers on top of the wheel and then try. Don't grip the wheel.
    Was some advice given by another driver. (If backing a 28 foot single, then use one finger on top.)
    But cool your jets. These things don't move fast in any direction, reverse included. Calm and cool gets to be your friend real fast.
    I had troubles with the 90 and 45. Most days now I'm fine, every once in a while I can't get the angle right.
    Although, today I had an odd occurrence. In my personal vehicle I found myself trying to back an invisible trailer... That was amusing for a moment wondering why my personal vehicle wasn't turning the right way.
    Tonitos, enicolasy, 91B20H8 and 2 others Thank this.
