We have a Western Star 4964FA.......really like it.
Looking at adding a 4964SA.........but wondering about the ride........haven't checked the actual inches from front axle to cab yet on the two.......might not be that bad.
This truck will see a lot of gravel roads and state highways, as compared to interstate driving.
Thanks for your comments.
Anyone have experiences with 4964SA, vs FX? What is ride like?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jakescia, Aug 8, 2008.
I have a 2001, 244" wheelbase (for parts of Canada), 84" sleeper. I run mainly northern B.C., Yukon, NWT, and Alaska. Lots of gravel road and poor ashphalt. I do lots of deliveries at mine sites, some of which require being towed by a cat. This is to let you know the conditions I operate in. I've always found the ride to be good. If you need measurements let me know and as soon as I recieve your cheque I'll get the tape measure out.
Oh what the he77, for a fellow Star man I'll forgo my usual fee and do it for nothing. Let me know what you need.
One word of caution. Watch your sleeper size. Depending on kingpin setting and wether you have a headache rack clearance can get a tad cramped. There are times I wish I had more room twixt the trailer and headache rack. -
I'm driving one now, same wheelbase,4964SA. There is too much space between the extensions and the front of the trailer for good aerodynamics, too much weight on the front axle with the 5th wheel slid up. It is a 75 or 82 inch sleeper.
I like the 4964FA, with that same wheelbase and sleeper allows easier placement of the fifth wheel and probably a slightly better ride, the ride isn't bad with the setback axle. either. -
My primary interest is the ride between the 4964FA and the 4964SA...........
I found on the WS website that the distance between the steer axle and back of a daycab is 9 inches different for 4964FA and EX.......but is 17 inches shorter for the 4964SA as compared to the FA. (That would make the difference between the EX and the SA 26inches-------obviously.)
That would seem to be quite a bit, and would translate into a significantly rougher ride, especially unloaded........but I just have no frame of reference to decide for sure.
Any enlightenment you can send my way would be greatly appreciated.
Thanks. -
If both trucks are spec'd the same, the SA should give you a better ride off road and I also found they stand up a bit better in the corners.
I would have guessed the longer wheelbase-to-driver would give a better ride offroad????
But.....our actual "offroad" driving has been pretty minimal........so I have little to compare.
Thanks. -
I been truck shopping recently and didn't know much about the newer Western Stars but liked the look of them. Was speaking with a salesman at a midwestern WS dealership who seemed knowledgeable. He told me to avoid 2001 - 2002 models made in the USA because the company was bought out by Volvo? (I forget who?) in 2000 or 2001 and the quality and fit/finish went in the toilet for a couple years. He said the Canadian made ones were fine. Anyway, I have no personal experience, just what I heard. Maybe someone will put in their 2 cents with real experience?
I think Western Star was bought out by Dalmer Chrysler which also so own's many company's like Freightliner,Mercedees Benz, ect they moved the plant to Oregon from British Columbia there might of been some start up problem's and getting the kink's out of the new factory but other than that I havn't heard of any rel issue's they had. I have known of several trucks purchaced in those years and they didn't seem to be any better or worse than the Canadian built ones
My 01 was built in Kelowna. I believe, but not 100% sure it was 03 before they were built in Portland. I know it was quite awhile after Terry Peabody sold Western Star. They brought quite a few of the Kelowna people to Portland. I hauled 8 loads of machinery from Kelowna to Portland.
I've run Stars since 64 and cried when Freightliner bought them. My theory is there nothing in this world so good that Freightliner can't make it bad and nothing so bad Freightliner can't make it worse.
I was at the Portland plant last year and was told they build Freightliners to last 3 years and Stars to last 15.Markvfl Thanks this.
