I got a 07 columbia with c15 acert waterpump leaks when the truck is off n cold. I use to work on cars before I started driving a truck, so I don't think it will that hard of a job. I just need instruction on how to remove and install the waterpump and any kind of tips you guys have, also going to replace the t-sats. And thank you guys in advance.
Anyone have instruction on how to replace waterpump
Discussion in 'Freightliner Forum' started by SimD, Dec 25, 2012.
cat water pumps are not really bad just drain all coolant in big pan loosen the hoses and remove the bolts take it off! and thermostats replace them and gaskets and put all back together and fill with good coolant try ext life the red is good no additives needed!!! check all bolts and hoses they are tight !!
Do you know the instructions for the water pump removal?
The ninstructions are as follows 1. Start unbolting stuff 2. Remember where it all went.
Kendall427 Thanks this. -
Okay wise guy, I don't understand people if you can't be a help to someone why make smarta** remark
I did the pump on my S60 and all it is 2 large hoses 2 small hoses and 4 bolts. Hes not trying to be a smarta$$ he letting you know it is very easy to do and the way he explaind it is the same way I did mine in the driveway in a few hours.
