Anyone installed AirDog Caterpillar Secondary Fuel System Upgrade Kit on 3406E or C15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Slow302, Jun 16, 2020.
  1. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
  3. Slow302
    348
    117
    Jul 12, 2013
    MO
    Looks like i wont be doing this upgrade kit on my 3406E. Fuel feed routing is different than on C15. On C15 fuel gres from transfer pump to filter base than to front of head, on 3406E goes from transfer pump to filter base than goes to ECM than to front of head. AirDog says i have to put "T" in line between filter base and ECM and than run it to the head. To me ECM will never know 100% how much how fuel went to the head. I will just replace original lines with new one and maybe install AirDog Champ 2
  4. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    The ecm don't care how much fuel goes through it the fuel that does go though ecm is to cool it that it
  5. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Fuel doesn’t even need to go through the ecm.
    wore out Thanks this.
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    it does on a 40 pin ecm may not have to but does
  7. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Why? How is the 40 pin ecm any different than the others?
  8. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    early cat ecms were cooled by fuel I guess they ran to hot an burnt up
  9. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    well the difference is in the two fuel fittings sticking out the side
  10. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    same as a n14 there fuel runs through ecm
  11. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Fuel ran through early ecms because they thought it was necessary. Later on they quit it wasn’t needed.
    I don’t know how you would cool an ecm by running 180*+ fuel thru it.
