Anyone running steers on the drive position?
Discussion in 'Canadian Truckers Forum' started by Freightlinerbob, Sep 13, 2013.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Basically running western Canada to all points in the US and it's time for some new drive tires. So before I get another set of XDN2s....
    Is anyone running All Position tires for drives on a year round basis? I'd like to know:
    Any traction issues?
    Brand & model of tire?
    Life expectancy of tires?
    Would you do it again?
  3. Pinner
    Pinner Medium Load Member
    410
    201
    Feb 14, 2010
    B.C.
    Seems like a really bad idea to me
  4. abtrucker
    abtrucker Light Load Member
    131
    30
    Oct 23, 2011
    Alberta
    Does not seem cost effective to run steers on the drives. Are we talking trailer tires?
  5. Hammer166
    7,553
    27,498
    Aug 18, 2007
    ~8600+' and loving it!
    Bob, I've run XZE's on the drive before. Way better than a drive tread on ice or hard pack, not so good in deep, loose stuff. Loose snow on the highway was no real problem, but I had to be careful where I parked in the snow, as they won't dig themselves out of hole like a lug can. It was actually much less of a problem than I expected. Just make sure they are well siped, as that is where their traction advantage is on the hard slippery stuff. But I was amazed at how a rib-style tread could generate so much traction, especially as they were ready to be replaced by spring.
    They do have a shallower tread when new, but seemed to last almost as long as the regular drive tires. (On a carhauler 255/70 R22.5's don't last a real long time anyways, too high duty cycle on them skinny tires.) Fuel mileage was marginally better.
    And yes, I'd do it again
  6. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    According to Michelin's web site, XZA3+ on the drive position would save enough fuel to pay for themselves if I could get 250,000 miles out of them vs the XDN2.
    Plus I've already got XZA3+ on the steer and trailer there would be a cost savings in tire labour as well.
    abtrucker Thanks this.
  7. king Q
    king Q Road Train Member
    2,880
    3,032
    Jul 26, 2010
    Johannesburg sa
    When I was a driver I ran XZA's on the drives very successfully.
    These were 1100R20 tube type.
  8. LashLLC
    LashLLC Bobtail Member
    6
    Sep 11, 2013
    I run drive tires all around on the tractor. I have had no traction issues to speak of. When I need new tires in a drive position I usually put the new ones on the steer and move the current steer tires back. I get really long life on tires this way. The only traction issues that I faced was when parking. The warm tires melt the snow and you "drop" in and can be difficult to get out when parked in deep snow or on ice. When that is going to be an issue try to let the tires cool on the fuel island before you park or stay a few feet out of your spot until they cool a bit then back on in. I have also worked for a company that used all steers ran west coast and never had any issues either. Be smart and watch the weather. I try real hard to park during a bad snowstorm or ice. Use some common sense and you should be fine. Also if you buy regroovable tires you can get another 50 or 60k miles when you put them on the drives. I have 4 tires on the drives that have 200k on them right now. If I regroove them could expect another 50 to 60k out of them
  9. Pinner
    410
    201
    Feb 14, 2010
    B.C.
  10. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    Trailer tires will NOT work in a drive position very long. The tread is not designed for torque like in a drive application. I have known alot of guys running siped steers in a drive position and had minimal problems. I just bought a set of Toyo M657's w/ a RR of 106 and 28/32nd's for $3900 out the door. I do some offroad so a steer will not work in my application.
