Anyone running Steers on the Drives?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Freightlinerbob, May 11, 2013.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    How do they work in snow and ice?
    I imagine ice isn't much of an issue.
    Or with chains?
    Years ago I heard KR talk about some Canadians that just ran Canada having good success with this.
    I'm looking for low RR without going to LP 22.5s or singles due to having low gearing already.
    Anyone done this in the northwest year round?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    really steer tires gives u better MPG, but good on dry panement only. Wet pavement ore snow and u gotta tracktion problems.
    to lower RR change trailer tires with SS, better with European SS (385/65R22.5). Some truckers here change wheelhubs with european on drives and they use EU trailer single rims with 386/55R22.5 (narrower the SS, but may be used as single tire).
    The real problem is other. All these things are too expencive, and tires rated over 4000 kg + 20-50% for sterss are too expencive, so it is cheaper to use conventional twins with 3000 kg rating. The cheapest size here is 10R22.2
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    I talked to a driver running steers on the drive axles, he claimed they didn't cause many problems and were easier to chain up, due to a lack of lugs to catch the chains on.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I ran steer tires on my 8 drives one year & went thru the last & big snow storm in MI. had no problems.
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I run Goodyear 661 RSA on my tractor. Not state of the art tires, but short haul with heavy loads they stand up pretty well.
    They are horrible in the snow. On the main roads they suck, and uphill corners or off camber turns forget about it.
    I recap them with BDR w from bandag and run them in the winter. On steel rims....
    The Michelin fronts that are micro siped might be better..... In the snow. I don't chain , so can't help with that. If it snows that bad I sit in my house.
    I save about 3/10s in mpg between the two tread patterns..
  7. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I think that steer tires are a misnomer, they're all position. The Michelin XZA3's are excellent in a drive position especially on ice and wet roads.
    Semi Crazy Thanks this.
  8. Bikerboy
    Bikerboy Light Load Member
    299
    183
    Apr 1, 2008
    Canada
    If you like getting stuck in a couple inches of snow
  9. d281833
    881
    919
    May 15, 2012
    Have you had them for drives? What were they like?
  10. Bikerboy
    299
    183
    Apr 1, 2008
    Canada
    I just know I get stuck enough with heavy lug tires in wet or packed snow, so I wouldn't think steer tires would do very well if you get into any mud or snow
  11. d281833
    881
    919
    May 15, 2012
    Well I guess they wouldn't do any worse by the sounds of it. If you're stuck, you're stuck.
    Rockwyrm, magoo68 and Raiderfanatic Thank this.
