Anyone with a 4CK cat engine?
Discussion in 'Ask An Owner Operator' started by Epmtrucks, Jul 3, 2013.
  1. Epmtrucks
    Epmtrucks Medium Load Member
    319
    182
    Mar 31, 2013
    Just purchased a 94 KW with a very late model 4CK cat engine, well maintained PEEK engine, 460 HP, 550K on Cat inframe. 14.7L, 3406 C motor. Clean oil, rig dig and ecm reports. The C was only manufactured for 2 years, 1992 & 1993, the last of the PEEKS. they produced almost 25k. Mine is 23,723. then the Es came out in 1994. Ds never made it off the drawing board, What would have been an F is a C15, which is also a 14.7L. Except the 15.8L or C16 600 to 625 HP. The early PEEKS 1986 to 1992 where 3406B, also 14.7L. The A, B, C, E, & C15 all have the same bore and stroke. The C 16 has a bigger bore. The 4CK has a steel piston and a wider rod bearing than the A & B cats.
    Just wanting to know what to watch for, thanks.
    feldsforever Thanks this.
  3. wore out
    wore out Numbered Classic
    15,364
    185,494
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Not all C models had the wide rods, 12 point head bolts are usually a good indication that they are wide rods. The turbo lag on the 4CK engines can be corrected by making the ECM think it has 2 to 3 pounds of boost at idle. other than that treat it like any other CAT keep a tight overhead make sure the timing advance working properly and you should get good service. I do have a complete 4CK that a customer had me take out due to a knock, it was just a timing problem but he was hot to put a 1LW E in its place which was a pretty easy swap.
    cke, Oxbow and Epmtrucks Thank this.
  4. Epmtrucks
    319
    182
    Mar 31, 2013
    My 359 had the hood and radiator wiped out by a intoxicated Falcon FB driver on May 17th and I purchased the 94 so I can go back to work. It has a great, clean running 7FB 350 economy with a 13sp direct that I could swap for fuel milaage. The 4CK is a 12 point head bolt. It can be converted to manual, but I would need to find a late model mechanical B pump.
  5. wore out
    15,364
    185,494
    Jun 5, 2013
    Is the PEEK pump giving trouble, or would you just rather have the manual pump. I have got a lot of folks happy with their peek if they have a little patience and let me tune it. But I made a bunch happy by building them a mechanical pump and putting it on and tuning it as well and the peek stuff no one keeps there were so few and even fewer that haven't been converted. That 7FB 350 was bout the best all arund 3406 in my opinion if you decide not to keep it I would be interested
    cke and Epmtrucks Thank this.
  6. wore out
    15,364
    185,494
    Jun 5, 2013
    Is the PEEK pump giving trouble, or would you just rather have the manual pump. I have got a lot of folks happy with their peek if they have a little patience and let me tune it. But I made a bunch happy by building them a mechanical pump and putting it on and tuning it as well and the peek stuff no one keeps there were so few and even fewer that haven't been converted. That 7FB 350 was bout the best all arund 3406 in my opinion if you decide not to keep it I would be interested in it with a few minor adjustments a big detroit rad and air to air it doesn't get much better
    cke Thanks this.
  7. Epmtrucks
    319
    182
    Mar 31, 2013
    Just starting to get the 94 ready, wont know for a few thousand
    miles what I have. Drove it back 500 miles from Ga, did an oil sample, soot was 9 on 13K miles, so far its encouraging.
  8. wore out
    15,364
    185,494
    Jun 5, 2013
    Sounds like you got a good start so many wanna pour fuel into the combustion chamber and not give it any air without a dyno oil and fuel sampling are your next most valuable tool.
    cke and Oxbow Thank this.
  9. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    Not all C's where Peec engines. The C's were available as straight mechanical engines all the way up until 1997. Your injection pump can be converted to mechanical. There is no need to find a replacement if you choose to go that route.
  10. wore out
    15,364
    185,494
    Jun 5, 2013
    True as matter of fact the mechanical C is more common than the peek. The timing advance is bulkier on a c than a B I just never was a fan of converting the peek pump. Replacement with a factory manual pump works better. And yes the manual c pump is a little better than the B pump. Lots of stuff looks the same to the naked eye but you gotta be on top your game you go to mix matching paarts u can end up with a fuel drinking no pulling piece or you may get a real stump puller I don't like guessing the outcome I usually kknow
    cke Thanks this.
  11. Epmtrucks
    319
    182
    Mar 31, 2013
    4ck, 3406C, 460 HP, aprox 25000 where built 1991 through 1993, where the only ones to carry the C. Mine is 4CK23793, in a 94 KW, very close to the end of production.
    5EK, 1993 through 1997 3406E longest produced E model
    6TS, 1997 3406E
    1LW, 1998 3406E
    2WS, 1999 the last E 3406
    6NZ, 2000 - 2002 the first C15
    MBN BRIDGE 2002. C15
    Acert 2003. These all have the same bore and stroke, have a 14.7L displacement
    3ZJ, 1991 through 1995, 3406B ATAAC
    8PN, 1995 through..........3406B ATAAC, I have a friend who has one in a 1997 Pete, the last of the mechanical 425HP engines from the factory.
    wore out Thanks this.
