Anyplace in Newark NJ to get a Pete 579 used headlight?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by scoobertdoo, Mar 20, 2023.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Something from the road put a hole in the glass lens.... Need drivers side.
    Rideandrepair Thanks this.
  3. Rideandrepair
    17,423
    56,526
    Aug 8, 2015
    Maybe call Elizabeth Truck. They may know where to find one.
    scoobertdoo Thanks this.
  4. Rideandrepair
    17,423
    56,526
    Aug 8, 2015
  5. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Thanks, I'll call when the rest of the world wakes up lol
  6. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    No luck.
    Anyone have any luck with the aftermarket led assemblies?
  7. JB7
    JB7 Heavy Load Member
    952
    1,642
    Dec 13, 2022
    Laurel, MD
    heavytruckparts.net used $625
    Iowa80.com new $405
    truckpartsinventory.com black $375, chrome $430
    Not everyone may agree but for the most part aftermarket not worth it, cheaper for a reason, and most of the time it is much lower quality. OEM especially for anything engine or emission related. There are some exceptions. Say for Honda or Toyota Denso is the manufacturer and the same part can be purchased in a Denso box for less than what the same part is in a Honda or Toyota box.
    I have read that others who have used aftermarket bulbs say that the life is nowhere near as long as the original. If something were Sylvania I would use it as they manufacture a lot of the OEM. Interesting to hear any specific feedback on the aftermarket which you asked about.
  8. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    I've been using led bulbs for over 2 years, worked perfectly. Sadly my lens is broken,the bulbs work fine :D
  9. JB7
    952
    1,642
    Dec 13, 2022
    Laurel, MD
    In some units the headlight assembly has multiple LED's for the turn signals and marker lights. Other lights are the same way. When one part or light/bulb goes bad (not a broken lens) you just can't replace a bulb, the whole unit must be replaced. Unlike when a headlight bulb goes out. So if one goes cheap and the whole unit must be replaced prematurely it's going to cost more in the long run.
  10. Dave_in_AZ
    411,207
    Google truck wrecking yards in the area. Unfortunately, most of the wrecks probably kill the headlight buckets.
  11. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Clear flex tape will keep you going til you find something.
    I've patched my swimming pool with that stuff and the pool was full of water
