Anything Wrong With My Frame Painting Method?
Discussion in 'Ask An Owner Operator' started by Hilltop Hustler, May 8, 2025.
  1. Hilltop Hustler
    Hilltop Hustler Light Load Member
    79
    52
    Apr 29, 2023
    West Virginia, USA
    Step 1: Roll on Paint stripper out of a bucket
    Step 2: scrape off old paint with paint scraper
    Step 3: Belt Sand rust with 80 grit
    Step 4: Belt Sand rust with 120 grit
    Step 5: Spot Grind old paint and rust
    Step 6: Roll on primer with roller
    Step 7: Roll on Paint with roller x2
    Originally was going to buy a Sand blaster but silica is toxic and walnuts take longer. Also my preacher gifted me a handheld Belt sander. Also I do have a spray gun but my time with using a spray gun I'm constantly reminded of clogging spray guns.
    D.Tibbitt and Rideandrepair Thank this.
  3. Rideandrepair
    17,572
    56,927
    Aug 8, 2015
    @Tug Toy has an excellent thread on stretching and painting his frame. Looks great. Whatever he did. That’s my answer.
  4. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    guess it depends what you are doing or what kind of finished product you want.
    id say a belt sander won't be able to touch 65% of the frame easily from bolts and brackets being in the way.
    Old paint is a good primer as long as it's still stuck good so I wouldn't roll or spray on a stripper. Just remove what's loose.
    power washer and a needle scaler.
  5. abyliks
    abyliks Road Train Member
    4,141
    9,767
    May 2, 2010
    ludlow MA
    Start with a needler and a wire wheel, then bondo any low spots and sand, I would get some spray bombs for touch ups and those hard to reach spots
    make sure you block off air bags and usually sticking tin foil over air/electrical lines is easiest
    D.Tibbitt Thanks this.
  6. SmallPackage
    5,814
    18,631
    Dec 20, 2019
    Marion Texas
    A belt sander is not a good choice for automotive work. It will be ot get contours or around bolts and rivets without destruction. It will work fine on rails in the larger spots with no bolts or the whole rail if all the bolts are removed.
  7. AModelCat
    164,925
    I would hire someone to come and sandblast it.
  8. Ridgeline
    22,744
    123,743
    Do you wear a mask when you are using a sander?
    Hilltop Hustler Thanks this.
  9. FLHT
    FLHT Road Train Member
    1,434
    2,553
    Aug 2, 2014
    Water blast or walnut shell blast.
  10. W923
    W923 Road Train Member
    1,424
    4,410
    Feb 28, 2022
    First off I don’t want to sound like a party pooper but I do more of this kind of work as part of my welding and repair business than I would like to.
    I have no idea what the current condition of the frame is or what kind of coating is on it but a sander will not remove rust from the pits (assuming it’s pitted) and depending on the current coating paint stripper is likely to be rather ineffective.
    In my opinion if you care enough to be worried about doing a decent job you might as well do it right….if you just want to freshen things up for an auction….don’t put any more effort into it than half decent rattle cans.
    Sand blasting is very easy but requires lots of air to be efficient…we are running a large reciprocating compressor…70 ish cfm at 150 psi iirc….screw compressors are preferable but as I mentioned I’m not into this as a main line businesses just end up doing some of it. Depending on how bad the rust is and how much area you have it will take me several hours to close to a day to clean everything behind the cab on a truck….and that’s not counting removing air lines and wiring and other obstructions. With a normal 5hp shop compressor I would guess you are looking at a day plus of blast time. It takes between 750 and 1000 pounds of sand. Actually we use black diamond coal slag (supposedly much less health risk and cuts much faster than conventional sand). Some type of air supplied helmet is going to be pretty much needed for a job like this in my opinion….one can be made from a welding helmet and old jeans. the sand blast will reach farther than you can spray paint so you will need to get some brushes to get it into the deep crevices or rust will start there very quickly. As far as paint is concerned sherwin Williams is probably going to be your best value. We have had very good results with kembond hs primer or macropoxy for primer and then acrolon 218 for the top coat. Neither primer will brush or roll worth a #### in my experience. Kembond is easy to spray with a half decent gun. Macropoxy is a bit thicker and can pose some challenges.
    Acrolon is thick as well but thin it about 20 percent instead of the recommended 10 and it sprays fine….it’s also like it defys gravity….you can really pile it on and it won’t run. I am guessing it might brush decent because it’s pretty slow drying but I’ve never tried. Acrolon requires primer
    All of my listed paints are pretty bad for people so please wear some kind of paint mask.
    Opendeckin, Sons Hero, JB7 and 7 others Thank this.
  11. Hilltop Hustler
    79
    52
    Apr 29, 2023
    West Virginia, USA
    Yes
