Anytone AT6666. Squeal on transmit. Only on ch 19 AM
Discussion in 'CB Radio Forum' started by Timin770, May 26, 2021.
  1. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I've tested in a couple different vehicles and as a base station. Only squeals on transmit on ch 19. Anybody got a line on this?
  3. Lowboy456
    Lowboy456 Light Load Member
    278
    128
    Mar 14, 2017
    Do you have talk back on? I was wondering if it might be feeding back a little bit?
  4. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I don't think TalkBack was on I'll check it out when I return home this evening. I can't remember if it's possible to customize one channel with Talkback or not I'll have to look at that
  5. Lowboy456
    278
    128
    Mar 14, 2017
    I've never been around an Anytone 6666 but I've heard of them. I think Hardrive did a video of a 74 mile mobile to mobile transmission and the guy on the road had an Anytone 6666.
    Hardrive had his favorite Stryker 955.
    I didn't know but that radio packs some decent power right out of the box.
    While searching for its specs I found this nice window shopping CB site for truckers or hell anyone else that wants a CB. LOL!
    Walcott Radio
    10-Meter HAM Radios for Sale | 10-Meter Amateur Radios
  6. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Yeah I have been running my 655 (basically the same as the 955 minus SSB) until I figure out the Anytone problem. I also have a Northpoint NT-3-HP export radio I can use
  7. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Oh God how embarrassing. I discovered that my base station power supply voltage was bumped down to ~12.5 or 13.0 volts. I guess the radio needs a bit more. I then tested the radio in a couple of my 4-wheelers, still had squeal. Guess why. When I kicked my base station power supply back up into the 14+ area, I was ok.
  8. Lowboy456
    278
    128
    Mar 14, 2017
    Glad you found it! Sometimes we all get lucky now and then and its something simple.
    I was plagued with intermitent high SWR for several weeks every time Id' pull on the scales to weigh my rock in a couple of places. But then finally my radio quit transmitting completely with SRW off the scale on my Stryker 955 SWR meter.
    I plugged my backup radio in and still no go I thought it was working for a little while because it doesn't give me any SWR altert but soon found out no one was hearing me.
    After a day of that misery later that evening I ohmed out my coax and it checked out fine and in frustration I stared up at my antenna and noticed that the set screw in the antenna was gone. Well I'll be.......
    I reached up and sure enough I could pull the whip right out of its slot.
    The next problem was finding the right set screw to replace it with. What size was it?
    I could not find that info anywhere and I had to haul rock again next morning where I needed to converse with the scale house and loaders.
    Morning came and I still had nothing so at the last minute I grabbed a tiny strip of tin foil and wrapped one layer around it. That was too much to jam down in the hole so I trimmed it to where it went about 1/3 of the way around and left some hanging over the end to get started with. I jammed it in and it worked until I found the correct thread size and got a set screw from tractor supply. It was an 8/32 and I got the last one they had.:):biggrin_25520:Coolio!
  9. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Are you saying that when you put the anytone radio in the two 4x4's, the motors were turned off?
  10. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    I should have said "passenger cars". I'm thinking now I may have run this radio in a passenger car a while back and if memory serves, it ran ok. If it ran ok in a passenger car then, why not now? In any event its running fine now on 14.1v, so I'll keep an eye on it
