Anyway to bypass a regen?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by IROCUBabe, Sep 14, 2013.
  1. IROCUBabe
    IROCUBabe Road Train Member
    2,563
    1,024
    Apr 9, 2008
    Dallas, TX
    2008 Cascadia with a DD15, stop engine light, regen blinking, so stopped to do a regen this is the first parked one I've had to do. Well it's been doing it for like hours, no sign of stopping, clearly there is an issue. It's going into regen mode, idle bumps up like it's supposed to it just never freaking comes out of it. When I stop it myself it goes right back to stop engine blinking and regen light.
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    older cascadias have a mileage limit on dpf mine is every 300,000 miles only way to shut light and derate off was to clean dpf and reset code in ecm .this may be your problem
  4. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Sounds like maybe a bad pressure differential sensor.
  5. SpyderRyder
    SpyderRyder Medium Load Member
    341
    66
    Aug 29, 2011
    Rice, Texas
    I don't think the DD15 was available until 2010 and it came with SCR and not DPF. I have an '08 Cascadia and it is equipped with S60 14 Ltr 515 HP with DPF. The filter needs to be cleaned and tested every 375K. The regen system is an integral part of that system. My next new truck will be a glider kit with pre-EGR engine.
  6. Heavyd
    Heavyd Road Train Member
    7,763
    6,201
    Feb 4, 2009
    I don't know about the DD series, but with Cummins and Maxxforce(roll my eyes), once you get a stop engine light, this means you are at level 4 plugging severity which is the worst and must be dealt with only by tech with a computer. Driver initiated regens do nothing.
  7. IROCUBabe
    2,563
    1,024
    Apr 9, 2008
    Dallas, TX
    It is a DD15 and it is an 08 so you're wrong completely.
  8. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    Like Heavyd said he didnt know about DD series but he did know about the cummins and the maxxforce, which makes him absolutely right!
  9. SpyderRyder
    341
    66
    Aug 29, 2011
    Rice, Texas
    I stand corrected sir. Think you might use a little tact next time? So what is better, DPF or SCR?
  10. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    Pretty sure all SCR Engines have a DPF also.
  11. carlos70
    carlos70 Bobtail Member
    20
    5
    Nov 30, 2012
    Call Diesel Spec in Montreal. they can bypass it forever :)
