Anyway to help turning radius ??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tuckster, Nov 27, 2008.
  1. Tuckster
    Tuckster Light Load Member
    256
    29
    May 12, 2008
    Hanover, Va
    I'm afraid I already know the answer but here goes ....
    I bought a KW T600 on a W9 wheelbase and I'm beginning to regret it. It rides great and handles weight well but it turns like a truck !!! Any way to help the turning radius ??
  3. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    On my Truck I try to run most of the time with my Fifth wheel just a bit closer to my forward Drives than my Rear Drive, But it is just far enough that the Trailer doesn't hit my sleeper when I turn all the way either way. and If I have to move more weight over the steer tires I tape a note to my Steering wheel reminding me not to turn to tight while it is forward.
  4. DRB
    DRB Bobtail Member
    5
    Sep 27, 2008
    MOUNTAIN VIEW CA.
    This has been posted before with a new truck. I thought he should check his steering stops. Many new and old trucks have never been adjusted. Good luck and safe trucking.
  5. 05379
    05379 Light Load Member
    115
    Nov 15, 2008
    montague ma
    the factory had mine so i couldn't do a 360 in a football field haha some adjusting all set now.
  6. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    2004 W900,
    I found it helps if you jump out the truck, run to the rear of trailer, do a weightlifter squat, grab the DOT bumper, take a DEEP breath, lift, and walk in the opposite direction you want to turn.
    Seriously, I screwed my set stops in to the point that my left steer rubs HARD on the steerbox arm; not much help really.
    This truck turns tighter to the right.
    My '01 turned tighter to the left.
    My '96 turned tighter to the right..... What gives KW?
    There is a way to adjust some steerboxes, but a former company that I used to work for allowed the wrenches to adjust some of their T-800s that were in the oilfield. Frames began cracking at the steerbox area, and the truck gods found that said boxes had been adjusted.
    Bye- bye warranty....
  7. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Same here droy, adjusted mine as far as they would do to the point where the tire rubs on the box and still takes 100 acres to turn.... That and my 290" wb dont help.
  8. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Yeah, pull a spread then go back to a box...:biggrin_25523:
  9. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    Why are you trying to make it worse for him?....... Unless you flatbedders dont believe in lift axles and dump valves :biggrin_255:
  10. Tuckster
    256
    29
    May 12, 2008
    Hanover, Va
    Kenworth dealer strongly advises against it so I guess some of these off the suggestions may be appropriate !!! I'll just keep my eyes open for a football field. !!!!
  11. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    The companies don't after some drivers forget to drop the tag on a big coil rolling across the scale...:biggrin_2554:
