Application ?
Discussion in 'Questions From New Drivers' started by ford1998, Jan 17, 2011.
  1. ford1998
    ford1998 Bobtail Member
    20
    5
    Feb 19, 2010
    Portsmouth, VA
    How do companies check to see how many licenses you've had in the last three years?
  3. Mattkujata
    Mattkujata Medium Load Member
    309
    129
    Oct 25, 2010
    My guess would be you tell them up front. The reason being if you have had multiple licenses, and one of them has violations on it, and they find out, you're in deep doo doo.
  4. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    they will do a data search.......also you HAVE to list all drivers licenses you've held for 3 years....if you had one in a different state you are supposed to list it......if you don't and they do a search and turn it up forget about driving for them
  5. Jonny1
    Jonny1 Medium Load Member
    642
    191
    Jan 14, 2007
    Nashville, TN
    As Nic stated they have access to a data base and can retreve that information and records. What some people do not know is that these are subsciber based services like DAC or Hireright & they are given the ability to make comments.
    rocknroll nik Thanks this.
  6. wis bang
    wis bang Road Train Member
    3,392
    3,993
    Jan 12, 2011
    Levittown, PA
    If you have moved during the past three years and changed license state it usually shows on the abstract from DAC.
    Sometimes it shows the other state and license number so you know to run it too.
    Some states carry over the past few years from the other state and list it under the new license....
    FMCSR requires the carrier to run every license you've held during the past three years.
