Apu coolant use
Discussion in 'Ask An Owner Operator' started by Sphillips38, Nov 4, 2018.
  1. Sphillips38
    Sphillips38 Bobtail Member
    41
    7
    Oct 18, 2016
    24477
    Does anyone have a Thero king Tripac with the arctic package?
    If so,Does it use slot of coolant.Im seeing a loss of coolant in my truck.
    Thanks
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    After the initial instal, and topping the coolant back up, u shouldn’t see much of a coolant lose due to the apu
    Sphillips38 Thanks this.
  4. ttypewe4jim
    ttypewe4jim Light Load Member
    189
    142
    Feb 21, 2018
    What motor does your truck have? How many miles?... I'd do a pressure test on the system then check it from there. I'm assuming nothing is leaking onto the ground?
  5. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Also, open the oil fill when the truck engine is running hot and watch for steam.
    How much coolant are you losing?
  6. Sphillips38
    41
    7
    Oct 18, 2016
    24477
    345000.No visible sign of leaking
  7. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    How much coolant are you losing in how much time? You might have a leak directly over your exhaust, or an internal block leak.
  8. mitmaks
    mitmaks Road Train Member
    2,564
    2,077
    May 16, 2014
    Might be burning it, does it have EGR cooler DPF system?
  9. Sphillips38
    41
    7
    Oct 18, 2016
    24477
    Yes
