APU/heat unit broken in truck
Discussion in 'Questions From New Drivers' started by crabby125s girl, Dec 3, 2010.
  1. crabby125s girl
    crabby125s girl Heavy Load Member
    764
    309
    May 11, 2009
    My trucker has not had heat in his truck since last February.
    He works the NorthEast and has been to the Allentown, PA terminal about 5 times and to the ThermoKing once. Each time he goes he waits [unpaid] for days while they attempt to fix it but they've never fixed it. After each failed attempt he just leaves frustrated because he's got to make money! But usually in a month he comes back and they try again and fail.
    He msgs the "road breakdown' code in the qualcomm but they send him to either the terminal or thermoking, neither have been able to figure out how to fix his heat in almost a year!
    He's just become a trainer, which works well for him because when they're confident enough to run as a team the truck stays most of the day/night so he can sleep with the heat on while the trainee drives.
    But routinely Friday afternoons work slows down and he doesn't get an assignment until Saturday afternoon. So Friday nights he/they sleep in the truck, but the truck is not moving = no heat.
    And it's only going to get colder and colder.
    This Friday, like usual, he has downtime until Saturday afternoon but it's a little chilly. He asked his dispatch for a hotel room for him and his trainee so they don't sleep in the cold tonight and dispatch said NO!
    They said that they only get hotel rooms on hometime weekends, which this is not.
    Are they allowed to do this?
    I know right now it's not below freezing or anything but it plans to go down to 30 tonight [where he parks the truck] and it's only going to get worse.
    What is he supposed to do? Freeze because they can't figure out how to fix his heat for him?
    It doesn't seem like dispatch saying no to a hotel should be allowed or legal but we don't know what to do.
    Any input would be helpful, esp before tonight!
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
  4. crabby125s girl
    764
    309
    May 11, 2009
    nope he can't idle. Not allowed so the truck can't even do it. He's tried.
  5. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Ask them for the number to call when they are found frozen.
  6. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Not having heat I imagine would be a safety issue. He should still have a bunk heater besides the APU heater. If I were him I would give the company two choices, let me idle for heat or I am building a fire! I think he maybe fibbing a little to you. I can't see him shutting down in Minnesota and not being able to idle to keep from freezing to death.
  7. Panhandle flash
    Panhandle flash Road Train Member
    5,597
    6,014
    Jul 18, 2008
    Oklahoma City
    Geeze, its just one small little unit, wonder why they just don't replace it?
  8. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    I drove for a company with APU's.
    The idle of the truck is disabled and it would not idle when the apu died at 26 below one night.
    Had to start the truck every 4 minutes for about 2 hours to defrost it after waking up and finding it 19 degrees in the truck when the apu died.
  9. crabby125s girl
    764
    309
    May 11, 2009
    He once bought a 12 volt heater but it did nothing really. But it was super cheap so I guess that's why.
    The truck cannot idle, it shuts itself off. Believe me, before the trainer phase I was alone with him many cold nights last winter, if there was a way to idle or have heat at all he would have done it.
    When he goes to the terminal in PA, they don't give him a hotel room - I don't even know if there is a hotel nearby. In the past he's slept on the chairs in the lobby or waiting room or whatever it is, I don't know. Which is what I guess him and his trainee will be doing tonight. I don't know yet what will happen!
    We assume the APU is very expensive and that's why they don't replace it but who knows.
    I don't know what to do but if nothing changes he'll just freeze all winter, every year until he finds another job - and we all know how easy that is :biggrin_25523: or they assign him another truck but he's no where near the miliage amount to get another truck.
  10. chompi
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    It can be a serious matter if something happens out there in the winter and you do not have a back-up plan. My extreme back-up plan was that if I ever broke down and needed to keep warm in an emergency situation then i would start burning freight and then tires!
  11. crabby125s girl
    764
    309
    May 11, 2009
    And yes Roadmedic - my coldest night in the truck was 18 degrees INSIDE the truck. He has many blankets, since this problem has been going on since last winter but his trainee didn't know what he was getting into on his truck and did not bring a lot of heavy blankets, assuming the cab they'd be living in would be heated. He assumed wrong..
