APU information - anyone know about Power Cube brand?
Discussion in 'Experienced Truckers' Advice' started by Runnin, Sep 8, 2012.
  1. Runnin
    Runnin Light Load Member
    94
    59
    Sep 18, 2011
    Anyone have any current information on "Power Cube" APU system.
    Sales guy pushing it and I know very little about them. Any drivers using one now ?
    Thanks in advance for your time and advice.
  3. ml48603
    ml48603 Bobtail Member
    43
    11
    Jun 22, 2012
    The fuel consumption of an APU is much less than an engine idling for the same amount of time. You need to determine how much idle time you are using now.
    Calculate the cost of idle fuel per month, then calculate the APU's fuel usage per month for the same idle time, then subtract the two. Divide the cost of the APU installation by the dollars saved per month. If the payback period is reasonable to you than it might be worth getting an APU.
    I am trying to get hired on with a company that is using or moving toward APUs. Otherwise I will have to pay for the fuel to idle out of my own pocket if I want to stay warm or run my electric appliances on 10hr / 34hr periods and still meet the miles per gallon expectations of the company. At nearly $5/gallon that idle time will add up real fast on the meager wage a newbie like me is afforded.
  4. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,727
    16,491
    Jan 18, 2011
    Which one is the power cube? I am familar with the new electric Tri-paks by Thermo King--is that what you mean?
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    Ml48603 if ur company driver don't matter if they got an apu or not if so cool. If not idle the truck.
  6. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    I know my APU is a carrier, 1-3 gallon every 12 hours from what they say.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,731
    18,550
    Nov 1, 2010
    Burnsville, MN
    It's not just about $$$ saved per month, but how many miles it will take you to break even.
  8. TruckerSue
    TruckerSue Light Load Member
    178
    50
    Aug 28, 2012
    MISSOURI
    co tried that in my truck. Wouldn't cool off below 80 degrees or warm up over 35 degrees! so certified clean air idling is perfect for me. sleep like a baby in the truck even with the reefer going.:biggrin_25517:
  9. Runnin
    94
    59
    Sep 18, 2011
    Thanks all, I know what an APU is etc. What I was looking for was specifics
    on the brand "Power Cube". Am making the investment just trying to narrow
    down the field so to speak.
  10. lonelyswmtrucker
    lonelyswmtrucker Medium Load Member
    612
    248
    Sep 14, 2011
    down the bayou
    how well does the carrier apu cool & heat? i'm looking @ a truck that has 1 & unsure of them. how often do they need to be serviced etc?
  11. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Mine is serviced every time the truck is down in the shop.
    How well it performs depends on who works on it and if they know what their doing. A/C went out, Boyd serviced had A/C that night before it went out. Hauled it to a Carrier, first thing he says when I said the blower just got replaced, "Yup, Boyd has no idea what the the hell they're doing.
