Apu is leaking coolant
Discussion in 'Ask An Owner Operator' started by pumpkinishere, Dec 22, 2021.
Got it to stop leaking for the moment.
Rideandrepair Thanks this. -
Depends how they did the plumbing..
Some actually used shutoff valves during install that can be closed off and then bypass the APU.
If you have a Carrier, its probably the radiator.Magoo1968, Opendeckin, pumpkinishere and 1 other person Thank this. -
Shut off valves are something everyone should add. It'll cost you maybe $30 and a half hour.
Magoo1968, Opendeckin and pumpkinishere Thank this. -
There should have been shut offs installed from the installer
Mine are inside the frame a foot or so from the Apu itselfpumpkinishere Thanks this. -
I’ve used vise grips in the past to pinch off a hose on an APU to get back to the shop.
77fib77 Thanks this.
