APU kicks on too late
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Skull_Leader, Jan 11, 2013.
  1. Skull_Leader
    Skull_Leader Light Load Member
    67
    18
    Oct 23, 2012
    It eems like what is happening, is that the APU doesn't kick in until after the battery is so low that the truck turns everything off, and it does this nearly every hour. This wouldn't be so bad if I didn't have to lift my bed up, and reset the inverter before it kicks back on. I'm very light on electronics, but I want to get a refrigerator. I can't do that if I have no power for hours at a time before i realize that the poweris out again
    Ill be heading to a terminal tomorrow, but I've already told the mechanics about it, and they haven't been able top fix it yet. any clues about what this is and what I should do about it?
    Oh, and this is a 2010 pro star
    DoneYourWay Thanks this.
  3. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    What kind of APU? I had the same problem with a TriPac after I had my batteries changed. It turns out there is an adjustment in the controller that sets the turn-on point based on the current battery voltage. If that turn-on adjustment is set too low, your batteries will drain before the APU starts.
  4. J_FROG
    J_FROG Road Train Member
    1,061
    564
    Sep 4, 2011
    49 states and Canada
    Yes, there is a controller setting that must be adjusted. If your shop has someone that is trained by Tri pac they will know what to do.
  5. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Not sure but I think you have to have specific computer or some such device to plug into the APU to modify it's basic operational settings and thresholds.
  6. J_FROG
    1,061
    564
    Sep 4, 2011
    Not so, there are a lot of settings that can be changed through the controller. You just have to know how to do it and which ones to change.
  7. TonyUFN
    TonyUFN Bobtail Member
    13
    6
    Oct 22, 2008
    Gilmer, TX
