APU on VOLVO 670
Discussion in 'Volvo Forum' started by 05vnl670, Jun 26, 2014.
  1. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    I just got a rig master apu from mine friend that was seling his truck, mine questionis wher you mount it on volvo with full sied panels. I see some space in front of fuel tank on right side but the truck has ZF meritor trans and it has a air tank for trans mounted to the frame, I have 125 galon tanks so it dont help. Any sugestions,pictures?
  3. BobcatVolvo
    BobcatVolvo Light Load Member
    171
    132
    Feb 23, 2014
    Western Ohio
    Whew, talk about putting ten pounds of poop into a 5 pound bag. That is going to be tight, it may take some engineering.
  4. Chinatown
    Chinatown Road Train Member
    77,045
    179,959
    Aug 28, 2011
    Henderson, NV & Orient
    May have to install a smaller fuel tank on one side.
  5. RogueX
    RogueX Light Load Member
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    I have a 780 also with 125 gal tanks, full fairings. When I was considering buying an APU I was going to mount it under the passenger door. All my truck has there are chain racks which could be easily removed, plenty of room for an APU. The 670 may have that side's fuel tank mounted too far forward to do that however, plus you mentioned that air tank... I would try to have it mounted on or just forward of the catwalk, as close to the rear panel of the sleeper as you can. I've seen several rigs set up like that. Good luck:biggrin_25525:
  6. Moneymike
    Moneymike Light Load Member
    118
    31
    Apr 17, 2013
    On my 04' 670 with 125 gal tanks my TK is mounted in front on fuel tank on passenger side. Side note: I bought my APU after I got the truck. When I did my research the ringmaster was rated ....POOP!!!
  7. SpiritWolf
    SpiritWolf Light Load Member
    192
    118
    Jul 10, 2012
    North Highlands CA
    I saw a 670 with an APU mounted on the back deck. Not sure if that helps, but It could be an option if it doesnt fit under the fairings.
  8. spicyville1
    spicyville1 Bobtail Member
    15
    Nov 18, 2012
    I have an 06 670 and my rig master is mounted just in front of the passenger side fuel tank. Look at any Koch Trucking Volvo's,that is where they mounted all their rig masters.
  9. browndawg
    browndawg Medium Load Member
    676
    1,213
    Dec 20, 2013
    Rock Island, IL
    I have a ? for u guys with Volvos and apu's. my company has carriers on Volvo's with full fairings, they are mounted in front of fuel tank on driver side. anyone ever worry about exhaust fumes entering the sleeper the exhaust pipe is ran to edge of fairing and pointed down I am just curious as most tractors I see them mounted just in front of quarter fender with exhaust pointed towards drive tires. my company says that on Volvos this is the only way to mount them (in front of fuel tanks) if there is no breeze I would think the exhaust from apu can go under sleeper and possible seep in thru small gaps and cracks and what not or possible the side storage bin doors under the bunk.
